August 20, 20159 yr comment_476100 nice! where did you wind up w/timing? any obstruction to intake will affect flow - you can tune for some of it w/afr but it will always be there. i've spent quite a bit of time w/motorcycles on the dyno and every little bit counts. unless you're on the track you feel a few hp a lot less in a car than on a bike though. i was shocked at how much difference a set of screens made on the intake bellmouth, but if you think about it all screens have a % open area spec and even a fine wire mesh with large openings (filters out bugs/rocks but does nothing for dust & grit) will choke out 5-10% and that's a direct reduction to intake. end of the day, for street driving the filter effect will be essentially negligible and your bores will thank you... Link to comment https://www.classiczcars.com/forums/topic/49193-my-datsun-280z-rustoration/?&page=44#findComment-476100 Share on other sites More sharing options...
August 20, 20159 yr comment_476101 On 8/20/2015 at 2:16 AM, HaZmatt said: Yes I got most of my M8-M12 bolts from Fastenal. The M5-M6 bolts I got from ClipsandFasteners.com. The specialty Datsun hardware I had plated at a local plating shop.Thanks, appreciate it. Awesome build.Sent from my A0001 using Tapatalk Link to comment https://www.classiczcars.com/forums/topic/49193-my-datsun-280z-rustoration/?&page=44#findComment-476101 Share on other sites More sharing options...
August 20, 20159 yr Author comment_476102 Not sure what we ended up with timing. I think its slightly advanced. I will be running the filters on the street and normal driving situations, I was just curious to see what the difference was. Link to comment https://www.classiczcars.com/forums/topic/49193-my-datsun-280z-rustoration/?&page=44#findComment-476102 Share on other sites More sharing options...
September 12, 20159 yr comment_477409 Just got done reading the thread. Great read. The car really had everyone fooled at the show and shine last month. Almost fooled me when i saw the brackets for the 280z front signals. You did a great job on the build. The car looks great. Are you going to the cussler collection tomorrow? Link to comment https://www.classiczcars.com/forums/topic/49193-my-datsun-280z-rustoration/?&page=44#findComment-477409 Share on other sites More sharing options...
September 12, 20159 yr Author comment_477431 Thanks Darrel, no I didnt hear about it. Wheres it at? Link to comment https://www.classiczcars.com/forums/topic/49193-my-datsun-280z-rustoration/?&page=44#findComment-477431 Share on other sites More sharing options...
September 24, 20159 yr comment_477963 On 5/17/2015 at 2:59 AM, HaZmatt said: DSC_1044.JPG Now for the fronts DSC_0026.JPG DSC_0031.JPG DSC_0034.JPG DSC_0038.JPG DSC_0044.JPG DSC_0047.JPG DSC_0051.JPG DSC_0053.JPG DSC_0055.JPG Hey Matt, can you shoot me the measurements you used for the cuts on the stock housings? Looks like about two inches on the rear, less on the fronts.... I would like to duplicate your stance eventually.... Link to comment https://www.classiczcars.com/forums/topic/49193-my-datsun-280z-rustoration/?&page=44#findComment-477963 Share on other sites More sharing options...
September 24, 20159 yr comment_477964 what the heck is going on.... Edited September 26, 20159 yr by wheee! Link to comment https://www.classiczcars.com/forums/topic/49193-my-datsun-280z-rustoration/?&page=44#findComment-477964 Share on other sites More sharing options...
September 24, 20159 yr comment_477965 why is the forum double/triple posting???? Edited September 26, 20159 yr by wheee! Link to comment https://www.classiczcars.com/forums/topic/49193-my-datsun-280z-rustoration/?&page=44#findComment-477965 Share on other sites More sharing options...
September 24, 20159 yr comment_477966 and again.... Edited September 26, 20159 yr by wheee! Link to comment https://www.classiczcars.com/forums/topic/49193-my-datsun-280z-rustoration/?&page=44#findComment-477966 Share on other sites More sharing options...
September 25, 20159 yr comment_478016 On 9/24/2015 at 4:37 PM, wheee! said: Hey Matt, can you shoot me the measurements you used for the cuts on the stock housings? Looks like about two inches on the rear, less on the fronts.... I would like to duplicate your stance eventually....Same here. Would be interested in the measurement as well. Link to comment https://www.classiczcars.com/forums/topic/49193-my-datsun-280z-rustoration/?&page=44#findComment-478016 Share on other sites More sharing options...
September 27, 20159 yr comment_478099 I am curious. I see you run no vacuum advance.Does Rebello really recommend that for the street? Link to comment https://www.classiczcars.com/forums/topic/49193-my-datsun-280z-rustoration/?&page=44#findComment-478099 Share on other sites More sharing options...
October 1, 20159 yr Author comment_478303 I had to cut the strut housings about 2" from the bottom. I ended up having to trim a little more off so the coilover would sit flush at the base. So about 1 15/16" Link to comment https://www.classiczcars.com/forums/topic/49193-my-datsun-280z-rustoration/?&page=44#findComment-478303 Share on other sites More sharing options...
