May 22, 20168 yr Author comment_495499 33 minutes ago, rossiz said: the kit i got provides two options: some double-stick tape and wide clips (like hazmatt shows) or smaller clips with sheet metal screws. i started with the stick-on system and mine didn't stick - the covers aren't a perfect fit (slight warp) so they put constant, light pressure on the adhesive which pulled them off. i then went to the drill-in method and they've been fine since. i am considering doing the door-trim trick now though, as the brightwork would look nice on my dark green paint. Interesting, mine only came with the stick on option. I guess if I had to I could drill a hole in each one. I would probably rivet them in. Mine were not a perfect fit either but pretty close. You just have to kinda split the difference in the gaps. The chrome would definitely look sharp on your car! I was surprised what a difference it made. Link to comment https://www.classiczcars.com/forums/topic/49193-my-datsun-280z-rustoration/?&page=50#findComment-495499 Share on other sites More sharing options...
May 22, 20168 yr comment_495504 Don't you have an issue with water seeping in through those gaps when you wash the car? Link to comment https://www.classiczcars.com/forums/topic/49193-my-datsun-280z-rustoration/?&page=50#findComment-495504 Share on other sites More sharing options...
May 22, 20168 yr Author comment_495505 2 minutes ago, dmoralesbello said: Don't you have an issue with water seeping in through those gaps when you wash the car? I just remove them when I wash it. Link to comment https://www.classiczcars.com/forums/topic/49193-my-datsun-280z-rustoration/?&page=50#findComment-495505 Share on other sites More sharing options...
May 23, 20168 yr comment_495529 yeah, water gets in and the scoops get dirty inside from the carwash and driving in the rain, but they drain out just fine. i stressed about it for the first few weeks and eventually just let go of it. every few months i'll pop off the covers and wipe out the scoops - it's no big deal. but my car is a dd, not a showpiece... Link to comment https://www.classiczcars.com/forums/topic/49193-my-datsun-280z-rustoration/?&page=50#findComment-495529 Share on other sites More sharing options...
May 26, 20168 yr comment_495740 HazMatt, gave your idea a try, looks much better than the rubber trim! Will work on a tighter fit next, but love the look! Link to comment https://www.classiczcars.com/forums/topic/49193-my-datsun-280z-rustoration/?&page=50#findComment-495740 Share on other sites More sharing options...
May 26, 20168 yr comment_495741 Another view ... Link to comment https://www.classiczcars.com/forums/topic/49193-my-datsun-280z-rustoration/?&page=50#findComment-495741 Share on other sites More sharing options...
May 26, 20168 yr Author comment_495743 51 minutes ago, duffman said: Another view ... That looks great! Nice work. I like the thicker edging. Link to comment https://www.classiczcars.com/forums/topic/49193-my-datsun-280z-rustoration/?&page=50#findComment-495743 Share on other sites More sharing options...
May 26, 20168 yr comment_495749 Love that look as well Duffman and (very surprisingly) I think I prefer the "smaller diameter " chrome trim fitting inside the edge of the of the bucket and flush with the body than the original JDM trim ring. Didn't expect that at all! My only suggestion would be to paint body color the portion of the mounting bracket that sits on the bucket. That would camouflage it nicely. Edited May 26, 20168 yr by dmoralesbello Link to comment https://www.classiczcars.com/forums/topic/49193-my-datsun-280z-rustoration/?&page=50#findComment-495749 Share on other sites More sharing options...
August 26, 20168 yr Author comment_501819 Some new shots of the Z after a fresh detail and wax. Enjoy. Link to comment https://www.classiczcars.com/forums/topic/49193-my-datsun-280z-rustoration/?&page=50#findComment-501819 Share on other sites More sharing options...
August 26, 20168 yr comment_501832 Ready for the show and shine on sunday at Boulder Nissan? Link to comment https://www.classiczcars.com/forums/topic/49193-my-datsun-280z-rustoration/?&page=50#findComment-501832 Share on other sites More sharing options...
November 25, 20168 yr comment_506982 This is a really great idea. What I was wondering was did you use the U channel trim or just a Flat trim that would adhere to the outside of the lense. Thanks Link to comment https://www.classiczcars.com/forums/topic/49193-my-datsun-280z-rustoration/?&page=50#findComment-506982 Share on other sites More sharing options...
November 30, 20168 yr Author comment_507153 On 11/25/2016 at 11:42 AM, chiefmd said: This is a really great idea. What I was wondering was did you use the U channel trim or just a Flat trim that would adhere to the outside of the lense. Thanks I used the U channel trim. Link to comment https://www.classiczcars.com/forums/topic/49193-my-datsun-280z-rustoration/?&page=50#findComment-507153 Share on other sites More sharing options...
