Did an alternator upgrade this weekend. Got the 90amp TYC unit with an internal voltage regulator from Z Car depot.
Straight forward install but bypassing the VR wiring threw my for a loop. All the diagrams I found online had different color wires than what I had. Apparently some 75' models are different than others. But after some research I found a thread by Tamo3 that helped me. Soooo thanks to you my friend!
Installed
Anyone know what this is and if there is a way to remove it or upgrade to something better? The exposed hot leads out in the open just doesn't sit well with me, plus its ugly.
Edited by HaZmatt
  • 1 month later...
