Swell!!....
rcb280z
My original tach would "hang high" when it got hot in the car. 1976 280Z. Mid-summer, after a long drive, it just wouldn't come back down, it hung at around 2500 RPM, I think. After everything cooled, it went back to to normal. I got tired of it and swapped a 1978 tach in.
I don't really understand how these tachs work, so couldn't even guess on a cause.
Edited by Zed Head
There might be a transistor amplifier that drives the tach needle that might not be well stabilized against temperature variations. All I know about that is that one way for the designer to temperature stabilize a transistor amplifier is to put a resistor in series with the emitter of the transistor and ground. Maybe the designer selected the wrong resistor value or the resistor has changed in value with time, I have seen them change in old radio equipment. I wouldn't know what else to guess though.
How many condensers are there? There is the one for the alternator and that is the only one I can think of at the moment without digging thru the manual. Which I do not feel like doing after the day I've had. I know, no excuse :ermm:
I can think of three, just from memory. The one on the alternator. Another is located near the voltage regulator, A/C relay under the metal bracket the fusable links are mounted on. The third is mounted on the coil and has two wires coming out of it.
I have seen a thread here from a member in Italy and he thought it had 6 or 7, but I can't find the thread right now. There could be more under the dash, need to dig through the manual to find out.
Chase
  • Who's Online   1 Member, 0 Anonymous, 334 Guests (See full list)
