After working on the 240 for 4 months and thinking i had it good i found i was wrong. It is idling so bad, ive tuned it and its great when driving but it vibrates really bad when idling and sounds awful. Any suggestions?
https://www.classiczcars.com/forums/topic/49309-really-bad-idle/
causes of bad idle, in order of probability
vacuum leak
vacuum leak
leakage of vacuum
carbs out of sync or adjustment
weak or out of time ignition. cap/rotor/plugs/wires/timing
cylinder/valve leakage, check with compression test
testing all of the above and finding a vacuum leak anyway
Make sure the choke linkage isn't stuck under each carb. Reach under each carb and push each nozzle upward. A stuck choke makes for a miserable idle and is fairly common in the Hitachi carbs. If one or both are stuck, your plugs should be black.
Edited by Diseazd
