tick tick tick
cardogman1
Lift the front end and spin the wheel.
Check the valve lash.
Chech the rivits on the brake pads.
Check the rotar face for run-out with a dial indicator.
I hope you find it before you pull all your hair out!
My 2 cents.
- Jeff
its a gremlinROFL and its going to be hard to find
i would check the intake exhaust gaskets, fan, wheels for warn parts, rotors, bearings and the like.
if it is suspension related meaning you just noticed this after the suspension work, i would think to check in that area first and work your way from there.
no way to really tell. just go over your front end really good with the wheels off the ground
Don't worry. You can buy a kit that will mask the sound. What it is is counting the rotations of your wheels. That is why almost all Z make the sound. I don't know the name of the kit off the top of my head but I'll check around. Don't worry, your car is not falling apart.
