So am I to understand correctly that If I get a "1" on the meter after testing for resistance on the other pin that means I have zero resistance? If thats the case then the thermotime is good.
It seems to be open then. Now you have to consider temperature. It opens at 57 - 72 degrees F. Down in CA, it should probably be open by now. Google says you're at 70 F.
Might have to wait until it's cold, or pull it and put in the refrigerator. In the meantime, are you sure that your fuel pressure is holding? A dry fuel rail will cause a similar problem.
No, the fuel pressure doesn't hold. I have a gauge on the "supply" side between filter and rail and it drops off over a few hours. Maybe I just think it should be cool enough for it to work. Im in Oxnard, a few degrees cooler than Ventura. Right now at the Oxnard Airport it is 67 degrees. This morning when I tried starting it it was 59 degrees, should have worked then.
Seems odd that it would only open between 57 and 72 degrees. What if its -57 degrees?
Edited by rcb280z
I should have said "switches", in that range. I was thinking in one direction, warming. In the other direction, cooling, it would close in that range.
How hard is hard to start? Maybe you're asking too much of an old car.
I don't think there's anything about an old car that should keep it from starting reliably, but this may be a case of an old DESIGN not starting as easily as a modern one. Back in the day, we would frequently have to bump the starter a couple of times to get running.
An interesting mod might be a push-button under the edge of the dash (or somewhere where it is not easily pressed by accident) that would actuate the CSV. We could use it like the priming bulb on a lawnmower! Of course it would be easy to prime too much and flood the engine.
Hi FastWomen, I had a thought last night regarding the Z running a little lean. It showed it in the emissions test I just had so I knew I could richen her up a bit. So I adjusted the bypass screw in about a full turn and when I started her up this morning it fired up the way it is supposed to, right away. So if it does the same tomorrow morning I'll know that I have fixed the problem, so to speak. And my fuel pump check valve is bad, doesn't hold pressure past 5 hours. So I think that is pretty good.
I wired in a toggle switch to the CSV about five years ago while I was waiting for my thermo time switch to show up. It worked perfectly for that whole week. Better than the cold start system "sometimes". If I ever need to wire the toggle back in it's in my toolbox ready to go.
RCB, Interesting about your bypass screw! I've adjusted mine in and out -- from all the way closed to screwed out almost to the point of falling out -- and it doesn't impact my idle mixture the tiniest bit! I wonder why. It doesn't seem to be clogged or anything.
Although it would be great if your check valve held pressure longer than 5 hr, I think 5 hr is certainly enough. As I understand it, the Nissan dealerships had a policy of replacing them if they didn't hold pressure for at least 2 hr, so they would have considered your check valve still good. Their only purpose was preventing hot restart problems, which apparently you're not experiencing (much).
