Looking to buy my 1st (to me) 240z.
SERE Nate
Long story short, my father had a 72 240z that we were going to fix as a father son project. Unfortunately he passed before it could become a reality and its time to find a 240z of my own to build with my sons.
I have a starting budget of around $4k.
I live in Spokane Wa and am willing to travel 500 miles or so for the right vehicle.
I have found a 72 240z that is a few hours away from me. The owner know nothing about the car. I have talked him down to $1500 for it and might be able to get if for a little less. He says that there is no visible rust and the the motor ran when he got it, but wouldn't hold a charge. Would run for a few hours on a full battery charge, then would stop running. Not it won't start and he thinks its a fuel pump.
He thinks that it has the 2.8 and not the 2.4.
Here are the pics that I have of it. Does this look like a good cat to start with?
1972 Datsun 240z
Look at the flat spot on the block between the #5 and #6 plugs for a stamping that says L24, L26 or L28. That will tell you the size of the block. The head ID is cast in the head by the #1 plug. Look for E31, E88, N42, etc.
From what I can see the car looks good for $1500. I'd like to see some pictures of the front shock towers and front wheel wells since those are common rust areas.
Chuck
the panel gap at the rf fender/passenger door looks pretty wonky... if they took fenders off, were they doing structural repairs and/or body work?
biggest worries are hidden structural rust. just about anything can be fixed/restored (there are some really great threads that have come up recently with incredible restorations and a lot of d.i.y. work) but it does come down to how much time you want to spend, and the old "pay me now or later" adage. if you want it to be a project where the process is the important part and the end product isn't tied to a timeline, then no worries.
my past experience has steered me to always spend a little more up front to get a better starting point - but that's because i have neither the skills nor budget to do a lot of body work...
Several things to consider; RUST The #1 problem with Zs. Take an ice pick & poke any blisters(paint or rust)-Fender wells, body below the doors, frame rails, floor pan, spare tire well, seat supports, cowel in front of the windshield, pull the battery, this a notorious place for rust. VOE I scanned the project 260 that I bought last fall fairly well for rust, or so I thought, Things I missed; Seat support, Hole in the rear of the right fender well. Behind & below the battery. OK I can deal with it, then I open up the right frame rail from the inside.I haven't seen that much rust since I left the ship repair yards. My 6 month project no longer has a definitive on the road date. OK, Engine,a working starter & a battery will allow you to do a compression check. The dash looks good, could mean a car that has been under cover much of it's life. Enjoy the project.
In the picture through the driver's door, the dash appears to have numerous cracks on top. For whatever reason, no pictures of the left side of the car.
Some things to consider:
What's your restoration budget?
How much of the work can you do yourself?
Do you have access to a parts car, local Pick-A-Part, or wrecking yard that has Zs?
A quick inventory indicates you'll need:
New bumpers
Bumper mounts
Outside marker lights
Windshield chrome trim
Steering wheel
New center radio/heat control panel
Radio
Seat covers
Door panels
Assorted door pieces, window cranks, lock knobs, inside release trim
Carpet
Possibly a new center console
Inner & outer shift boots
Outside body emblems
And, all the things you discover needing fixing and replacement along the way
Just those items could be a few thousand dollars depending on how sourced.
Depending on how big a project you're willing to take on, you may want to keep looking. Let us know what you do.
Dennis
Edited by psdenno
I can throw $1-2k per month at this if I need to. I would like to get it as a solid runner with nice stance, fenders, cowl, spoiler, rims & tires, and interior 1st. Then worry about paint, and over the winter have the powertrain beefed up to either a L28ET, SBC, or the SR26. I would like to end around 300 hp.
I am thinking $1500 for the car. $3-4k for astetics and suspension, $1k for the paint and body, and then $5k for the powertrain. If I can create a nice clean reliable driver with 300 hp for under $12k I would be very happy.
I do not have a garage at this time and will be needing to rent a spot for it. I need to be able to drive it to my in-laws garage for day long projects, but I cant store it there.
I do not have room for a parts car and I an not sure what the availability of used parts are here in Spokane Wa.
Here are a couple of pics of cars that I am trying to get mine to look like eventually.
Is my budget at all realistic????
  • Who's Online   0 Members, 0 Anonymous, 771 Guests (See full list)
