Distributor position?
JEFF
Pull the Valve cover and rotate the engine to TDC compression stroke one #1 cylinder. Both cam lobes should be pointing up.
Remove the dizzy cap and note the location of the rotor. it should be almost (2 ~ 16 degrees) to the #1 spark wire post on the dizzy cap.
If this checks out your ignition timing isn't the problem.
The problem was stuck rings!! A fresh hone - New rings.
Compression is 182 - 185 psi across all 6!! Fired up on first stroke!
I'm a happy man. Thanks for the help and suggestions guys!:classic:
