...like many beloved racers my luck has hit the wall.
Fuel gauge wasn't working on this car I bought a few weeks ago so I pulled the sending unit.
"Here's your sign" moment,
Followed by these findings,
Lemons to lemonade I shaved off 3/4s lb.,
Oh well, I bought it for me to have something to do. It has scored an A+ with this. :beer:
https://www.classiczcars.com/forums/topic/49439-developing-story/
I've got a step by step of my on that works pretty good, about four 5 gal. buckets and write down my next steps on a pad so as not to panick. And the 240 tanks are a hole lot easier (smaller) to slosh around. $30 for the Red-Kote liner, $20 for the muratic acid and acetone, gallon of each.
Question for you guys. Hopefully the baffle in the tank is only welded on the very bottom section? It steps down a couple of times before the actual lowest section so fuel can get around the sides, I'm hoping!
Thanks,
Cliff
I replaced my sending unit about five years ago and I remember scrambling to find a o-ring seal to go on the flange where it mates with tank. It would be a good idea to have one on hand as it doesn't come with the sending unit. Here is an image from the parts fiche, its item four p/n 17342-18000. I think it was metric but I don't have a record of the actual size.
Mike
Mike
You're right, I ordered one too. $1.54
LOL I have similar Sketchers...
You'd make a good FBI Agent, take in everything not just the obvious. Mine are Sanuks though, Sanuk Vagabond Brown - Zappos.com Free Shipping BOTH Ways
