is 100 a good price on a 280zx tranny?
inline4
100 is good. You could find a more expensive one if you want. To see if it is in good condition tilt the tranny on it's side and remove the drain plug. It has a magnet attached to it. Inspect the magnet it should have a real fine metallic powder on it, small amounts are normal. Unusually large pieces of metal is not good. This will only tell you if the tranny has been abused. The real test is to install it and run it.
To check if it's a five speed - attach the gear shift lever and go through the gears.
Originally posted by inline4
how expensive could a rebuild be?
I haven't priced one, but I'd expect to pay well over $500 for a complete rebuild of a 5 speed in the Bay area.
Call a local shop and ask. Estimates are free. If you're in the fremont area try Dando's.
