Posted June 16, 201410 yr comment_449929 Car is a 71 240Z with a 2.6 from a 260Z. SU carbs are from the 240. The car pulls away and make great power in 1st and 2nd gear until 2500 RPM, 3rd gear it makes power until 2300 RPM. Anything above that and its like someone let off the throttle, its just stops pulling. All plugs are the normal golden brown. Front carbs were slightly rich when I first received the car but I adjusted them. About 1/6 of a turn fixed that problem. Car has the points rebuilt when the engine was dropped in. I thinking it might be a fuel pressure problem but I dont have a gauge. Just though I would query you guys before I go buy a gauge.ThanksRyan Link to comment https://www.classiczcars.com/forums/topic/49461-car-stops-pulling-at-2500-rpm/ Share on other sites More sharing options...
June 16, 201410 yr comment_449930 Don't rule out ignition problems, especially the coil and any condensers that are on the distributor or coil. I'd actually test that first. Much simpler. Link to comment https://www.classiczcars.com/forums/topic/49461-car-stops-pulling-at-2500-rpm/#findComment-449930 Share on other sites More sharing options...
June 16, 201410 yr comment_449932 Check for loose connections especially around the dizzy and follow Carls advice Link to comment https://www.classiczcars.com/forums/topic/49461-car-stops-pulling-at-2500-rpm/#findComment-449932 Share on other sites More sharing options...
June 17, 201410 yr comment_449934 Lots of detail about the engine but only "stops pulling" on the problem. Not much to go on. Does the tachometer needle do anything odd? Does the engine sound different? Do the RPM continue to rise just a much slower rate? How high can you go in RPM?Also, you don't say if you have a mechanical or electric fuel pump. The mechanical pumps pump more volume at higher RPM and control pressure through a relief valve. The electric may or may not use a regulator. What do you have?And points aren't rebuilt, just replaced, with gap or dwell set when installed. Could be a point gap problem. If the points don't stay open long enough (dwell) you'll get a weak spark. You should probably just do a basic tune-up before buying a gauge. Link to comment https://www.classiczcars.com/forums/topic/49461-car-stops-pulling-at-2500-rpm/#findComment-449934 Share on other sites More sharing options...
June 17, 201410 yr Author comment_449935 I will check that Arne, thanks. I was brought up in a fuel injected and now distributor-less world. Carbs are not my forte but I am learning . Link to comment https://www.classiczcars.com/forums/topic/49461-car-stops-pulling-at-2500-rpm/#findComment-449935 Share on other sites More sharing options...
June 17, 201410 yr comment_449936 Sounds like fuel starvation to me. Not ruling out ignition but a plugged filter will restrict RPMs under load. A quick check to see if it's lack of fuel, rev the engine, in neutral, to 6000 RPMs, If it happily revs with no load, it's lack of fuel, Another interesting symptom is the car will go the same MPH in any gear & no higher, When it happened to me, all of a sudden the car would not go over 45 MPH. Second, third or fourth gear, 45 MPH. No engine miss, the engine ran fine, My dad was my riding mech. that day & immediately knew what it was, I was able to blow out the filter by the fire wall as a roadside fix, Start with all the fuel filters. Possibly one in front of the tank, another at the fire wall & one on each carb. Fuel pump pressure & volume is next. Hope this helps. Link to comment https://www.classiczcars.com/forums/topic/49461-car-stops-pulling-at-2500-rpm/#findComment-449936 Share on other sites More sharing options...
June 17, 201410 yr Author comment_449939 Lots of detail about the engine but only "stops pulling" on the problem. Not much to go on. Does the tachometer needle do anything odd? Does the engine sound different? Do the RPM continue to rise just a much slower rate? How high can you go in RPM?Also, you don't say if you have a mechanical or electric fuel pump. The mechanical pumps pump more volume at higher RPM and control pressure through a relief valve. The electric may or may not use a regulator. What do you have? And points aren't rebuilt, just replaced, with gap or dwell set when installed. Could be a point gap problem. If the points don't stay open long enough (dwell) you'll get a weak spark. You should probably just do a basic tune-up before buying a gauge. The points were replaced and timing set by my mechanic, not sure if he set the dwell of gap. Car seems to be getting good spark. I had the plugs wires, rotor and cap replaced when the motor was swapped in. Feel like a noob here. I can manage to build a 93 Mustang LX coupe and swap a 4.6 4V cobra motor, 6 speed, big brakes, coilovers, hydroboost, and about a billion other things but can't figure out old carb motors. go figure, Thanks for the input. Time to learn some old school. Link to comment https://www.classiczcars.com/forums/topic/49461-car-stops-pulling-at-2500-rpm/#findComment-449939 Share on other sites More sharing options...
June 17, 201410 yr Author comment_449940 Sounds like fuel starvation to me. Not ruling out ignition but a plugged filter will restrict RPMs under load. A quick check to see if it's lack of fuel, rev the engine, in neutral, to 6000 RPMs, If it happily revs with no load, it's lack of fuel, Another interesting symptom is the car will go the same MPH in any gear & no higher, When it happened to me, all of a sudden the car would not go over 45 MPH. Second, third or fourth gear, 45 MPH. No engine miss, the engine ran fine, My dad was my riding mech. that day & immediately knew what it was, I was able to blow out the filter by the fire wall as a roadside fix, Start with all the fuel filters. Possibly one in front of the tank, another at the fire wall & one on each carb. Fuel pump pressure & volume is next. Hope this helps.It revs freely to 4500, I will try 6K tomorrow. My personal experience is telling me fuel issues but I also listening to other more experienced carb guys. Friend told me to pull out the choke a little and see if it will rev a little higher. Link to comment https://www.classiczcars.com/forums/topic/49461-car-stops-pulling-at-2500-rpm/#findComment-449940 Share on other sites More sharing options...
June 17, 201410 yr comment_449946 I went through pretty much the same with a 240 I bought a month or so ago. I replaced the distributor and coil with the newer ZX's electronic ignition. It let it go past the 2500 rpm stall, under a load, it would rev up fine sitting in the garage. If you want to rule out fuel starvation, secure a gas jug in front of the radiator. Drill 2 holes in the top and run your fuel lines into the jug, supply and return. I put a shop towel around them then taped it up real good and went for a drive. Still wouldn't go past 2500 on the road.get one of these too, https://www.google.com/search?q=clear+glass+fuel+filter&rlz=1C1BOFA_enUS494US494&es_sm=93&source=lnms&tbm=isch&sa=X&ei=kgOgU5fDGIqeqAaskoGABg&ved=0CAcQ_AUoAg&biw=1280&bih=620I put one before the fuel pump and it would cloud up like a glass of tea but the bigger plastic filter caught the crap 1st. Now I'm in the middle of cleaning the tank and replacing fuel lines. Look at these photos, http://www.classiczcars.com/forums/funnybone/52471-developing-story.html Edited June 17, 201410 yr by siteunseen Link to comment https://www.classiczcars.com/forums/topic/49461-car-stops-pulling-at-2500-rpm/#findComment-449946 Share on other sites More sharing options...
June 17, 201410 yr Author comment_449964 Looks like it wont rev past 3500 RPM in neutral either. Link to comment https://www.classiczcars.com/forums/topic/49461-car-stops-pulling-at-2500-rpm/#findComment-449964 Share on other sites More sharing options...
June 17, 201410 yr comment_449965 It may be your coil? Mine was low and I could shake it to hear the sloshing of oil. Link to comment https://www.classiczcars.com/forums/topic/49461-car-stops-pulling-at-2500-rpm/#findComment-449965 Share on other sites More sharing options...
June 17, 201410 yr comment_449969 Check the wiring inside the distributor. Perhaps when the breaker plate moves from the vacuum advance it is causing a short or open circuit. There should be a small ground wire from the breaker plate to the distributor body. If that is missing or loose it could cause problems. Also, check the wire going from the points to the feed-through on the side of the distributor. Make sure it is not loose, frayed, has insulation worn off, etc. Link to comment https://www.classiczcars.com/forums/topic/49461-car-stops-pulling-at-2500-rpm/#findComment-449969 Share on other sites More sharing options...
