weird clicking, under the dash. is this normal?
2sixTZombii
Alright so when I drove my datsun with bad(really bad) brakes when I put the brake pedal down all sorts of clicking noises came from under the passenger side of the dash, like a relay only really fast. But now that I fixed the brakes that doesn't happen anymore. But when the key is in the "run" position, and while it is running, there is a relay click sound every ten seconds, under the dash on the passenger side, it sounds like its coming from this cluster of relays. I also hear a relay click every time I hit the horn. My question is, do all 260zs make this many relay cluck sounds or is there something wrong? If its normal, then fine but if its not, then WTH?
Alright so I do need to be concerned. What about when you hit your horn? Does a relay click then? I actually wasn't getting proper power to, where when converting to a internally regulated alternator the sense post is supposed to hook up. I suspected the amp gauge to be the culprit but it could linked this clicking relay.
  • Who's Online   0 Members, 0 Anonymous, 346 Guests (See full list)
