July 4, 201410 yr comment_450940 JGREEZY said: I'm pretty sure my Delorto's need to be tuned and maybe rebuilt. They idle really high also fall flat around 4500 rpm, also noticed fuel dripping from the first one last time. I'm not sure if that has to do with the carb's or if it is internal. the first thing I'll do is change the thermostat and plug the holes. from the mishap on Sun. If anyone else has had similar problems maybe can offer some advice.If it had been standing still for quite a while with fuel in the carbs, it could be overflowing, you could try cleaning the carbs. Link to comment https://www.classiczcars.com/forums/topic/49501-my-new-baby-72-240z/?&page=3#findComment-450940 Share on other sites More sharing options...
July 4, 201410 yr Author comment_450942 Yeah the carbs were gonna be the first on my list before the hoses busted. I'm kind of intimidated by it though. with my lack of experience with them. I'll just have to get the rebuild kit and a book and dive in. not too many shops in my area that are experienced with them. and I think I'll get a couple oem hoses and a new heater valve, and a thermostat and call it a day. Much easier on the wallet Link to comment https://www.classiczcars.com/forums/topic/49501-my-new-baby-72-240z/?&page=3#findComment-450942 Share on other sites More sharing options...
July 4, 201410 yr Author comment_450943 Do I have to remove the ac or just the blower? Link to comment https://www.classiczcars.com/forums/topic/49501-my-new-baby-72-240z/?&page=3#findComment-450943 Share on other sites More sharing options...
July 4, 201410 yr comment_450950 I'm hoping I can use a stubby screwdriver and a mirror to get to mine. Link to comment https://www.classiczcars.com/forums/topic/49501-my-new-baby-72-240z/?&page=3#findComment-450950 Share on other sites More sharing options...
July 4, 201410 yr comment_450958 JGREEZY said: Do I have to remove the ac or just the blower? This is what you have to deal with AFTER you get the A/C components out of the way. The squirrel-cage housing pretty well blocks all access to the hose clamps, hoses, and water ****. The housing is bolted to the firewall in at least two places as I recall. As to replacement radiator and heater hoses, stick with pre-bent versions and avoid collapses that will restrict coolant flow. Check out RockAuto for your radiator hoses - excellent values! Link to comment https://www.classiczcars.com/forums/topic/49501-my-new-baby-72-240z/?&page=3#findComment-450958 Share on other sites More sharing options...
July 4, 201410 yr comment_450979 Well damn! I may be without heat. I don't want to remove all that for a long time, when I restore it right, 10 years or so. Those hoses Bart's talking about are your A/C lines, they come in above the frame rail under the battery on my firewall. Here's my crusty valve and pinched hose, Link to comment https://www.classiczcars.com/forums/topic/49501-my-new-baby-72-240z/?&page=3#findComment-450979 Share on other sites More sharing options...
July 5, 201410 yr comment_451016 Ah those are the AC lines ok ! I was confused on that. We don't use much AC here.. Link to comment https://www.classiczcars.com/forums/topic/49501-my-new-baby-72-240z/?&page=3#findComment-451016 Share on other sites More sharing options...
July 5, 201410 yr Author comment_451021 Found the culprit first I removed the seat then I remove the glove box then drop the AC and the hamster cage then I can see the small hose attached to the heater control valve busted i'm going to change the Heater control valve and the hoses and I should be good Link to comment https://www.classiczcars.com/forums/topic/49501-my-new-baby-72-240z/?&page=3#findComment-451021 Share on other sites More sharing options...
July 5, 201410 yr Author comment_451022 Does anyone know the part numbers for the heater hoses I need the heater hose core inlet, and the heater hose inlet i'm going to try and go to the dealer tomorrow and see if I can get it over-the-counter Link to comment https://www.classiczcars.com/forums/topic/49501-my-new-baby-72-240z/?&page=3#findComment-451022 Share on other sites More sharing options...
July 5, 201410 yr comment_451023 In the "Teach a man to fish" theme: here's the link to the online parts catalog for the P/N's you need now and in the future.Datsun 240Z-260Z-280Z Parts Manual Link to comment https://www.classiczcars.com/forums/topic/49501-my-new-baby-72-240z/?&page=3#findComment-451023 Share on other sites More sharing options...
July 5, 201410 yr comment_451034 Looks like the one that busted is #10, Datsun 240Z Car Heater (To Jul.-'73)The replacement # is B7118 instead of 27118, according to online nissan parts storesThose worm gear clamps aren't original, somebody's been down that road already. Edited July 5, 201410 yr by siteunseen Link to comment https://www.classiczcars.com/forums/topic/49501-my-new-baby-72-240z/?&page=3#findComment-451034 Share on other sites More sharing options...
July 5, 201410 yr Author comment_451035 Now that I've got everything out of The way. I thought about it I'm not driving in the winter time. So I think I'm going to rip all that stuff out and plug it up. See how it cools Link to comment https://www.classiczcars.com/forums/topic/49501-my-new-baby-72-240z/?&page=3#findComment-451035 Share on other sites More sharing options...
