Recently Browsing 0
Using the Energy Suspension poly bushings (7-18102). Went to tighten down the sway bar end links but they didn't fit. The bolt would have to be about an inch longer. Not sure if the bushings are too big, the bold is too short, the spacer is too tall, or I just messed something up. I used the end link packet that did NOT have the square sway bar bushings (I assumed those were for the rear because nothing in the front has square bushings).
Any help?
Here is a picture of the car with the bolt nearly fully up AND the car on the ground.
https://www.classiczcars.com/forums/topic/49531-sway-bar-end-links/Share on other sites
