Posted July 7, 201410 yr comment_451101 There is a relay sound (ie, clicking sound, if that makes sense) from my tachometer area whenever I turn on my turn signals. Since owning the car, there was always a rapid clicking but it would settle in half a second and the signal would work as normal. Now, I only get rapid clicking and the signals don't work. Any idea what I would have to replace?The problem is for left and right, and I haven't done anything to the car so I'm guessing something just went out over time.EDIT: I should also note that the behavior still happens regardless of the turn signal lever. I tested that. Everything else seems to lead to the tachometer, which is where I'm stuck. Edited July 7, 201410 yr by aochider Link to comment https://www.classiczcars.com/forums/topic/49584-turn-signal-relay/ Share on other sites More sharing options...
July 7, 201410 yr comment_451113 Check for a burned-out signal light bulb Link to comment https://www.classiczcars.com/forums/topic/49584-turn-signal-relay/#findComment-451113 Share on other sites More sharing options...
July 7, 201410 yr Author comment_451117 Sorry to bother everyone with this. Figured out it was the turn signal flasher. Bought a new one and it works great. Thanks! Link to comment https://www.classiczcars.com/forums/topic/49584-turn-signal-relay/#findComment-451117 Share on other sites More sharing options...
