There is a relay sound (ie, clicking sound, if that makes sense) from my tachometer area whenever I turn on my turn signals. Since owning the car, there was always a rapid clicking but it would settle in half a second and the signal would work as normal. Now, I only get rapid clicking and the signals don't work. Any idea what I would have to replace?
The problem is for left and right, and I haven't done anything to the car so I'm guessing something just went out over time.
EDIT: I should also note that the behavior still happens regardless of the turn signal lever. I tested that. Everything else seems to lead to the tachometer, which is where I'm stuck.
Edited by aochider
https://www.classiczcars.com/forums/topic/49584-turn-signal-relay/
