EuroDat Posted May 17, 2015 Author Share #37 Posted May 17, 2015 (edited) Made a threw improvement to the instructions. Removed some typos en mistakes. Edit: Rev C - Abdreviations move to beginning and reference to kick panel removed. Thanks Tomo.Instruction - Fitting a 4-pin HEI module to 280Z 1977 RevC.pdf Edited May 17, 2015 by EuroDat Link to comment Share on other sites More sharing options...
TomoHawk Posted May 17, 2015 Share #38 Posted May 17, 2015 (edited) I didn't know the 1977 280Z had a passenger's side kick panel. Do you have a photo of it? Edited May 17, 2015 by TomoHawk Link to comment Share on other sites More sharing options...
EuroDat Posted May 17, 2015 Author Share #39 Posted May 17, 2015 I didn't know the 1977 280Z had a passenger's side kick panel. Do you have a photo of it? The document is quite good! A tip: we usually put the abbreviations and definitions near the beginning.I was wondering if it was original because it look modified and I couldn't remember one being there before this car. The PO probably mounted it for the speaker. I didn't refit it because the speaker was stuffed and missing its cover.Its laying around somewhere in one of the boxes of parts. I look for it and post some photo's of it. Thanks for the tip. Ill do that and remove the tekst about the kick panel. How are you going with your TIU. Having any luck finding a replacement? Chas Link to comment Share on other sites More sharing options...
TomoHawk Posted May 17, 2015 Share #40 Posted May 17, 2015 Thanks. I don't think I will be able to find a non-working TIU, because it usually just goes in the trash. Link to comment Share on other sites More sharing options...
TomoHawk Posted May 17, 2015 Share #41 Posted May 17, 2015 Maybe you could leave the reference to the kick panel, but just say to remove it if there is one there. Link to comment Share on other sites More sharing options...
TomoHawk Posted July 13, 2015 Share #42 Posted July 13, 2015 I made a simple wiring diagram of the setup Im now building. Its a little different around the resistor. Im using a 12V coil and bypassing the resistor. The wire from the ignition switch is connected, but doesn't have any purpose atm. 67436.attach Thanks to Wayne (wal280Z) for the awsome effort he has done with the color wiring diagram. Some photo's of the work in progress. 67428.attach I would suggest the use of the right-angle, or "flag" terminals, to reduce the size of things Link to comment Share on other sites More sharing options...
Zed Head Posted October 19, 2016 Share #43 Posted October 19, 2016 On 7/11/2014 at 0:28 PM, EuroDat said: I have been driving for a couple of days now and its still running much better. I must admit I was not to eager to drive it after all the problems, but now its brillant. My faith has returned. The engine revs hard to 6000rpm and sounds better than before. Not sure if thats due to the new coil or HEI module since I had to changed them at the same time. I think most of my problem was in the TIU. Once everything has proven itself, I will make a tech article maybe after I upgrade to the flame thrower. If anyone is interested in a base plate I made a simple drawing. Its on scale 1:1, but all the measurements are there so if the scale gets messed up it wont matter. Chas BasePlate001.pdf Hey EuroChas, I am about to link to this thread for someone that might be having a module problem. I'm pretty sure that your .pdf file is not in the Downloads area. Do you want to give it a look-over and upload it? It's definitely worth a spot there, probably in Tech Articles. @EuroDat Link to comment Share on other sites More sharing options...
EuroDat Posted October 20, 2016 Author Share #44 Posted October 20, 2016 Hi ZedHead, I made a tech article in the download section with the latest version. 3 Link to comment Share on other sites More sharing options...
wheee! Posted October 20, 2016 Share #45 Posted October 20, 2016 Awesome write up Chas! Thanks! 1 Link to comment Share on other sites More sharing options...
rcb280z Posted October 20, 2016 Share #46 Posted October 20, 2016 Wow, definitely an excellent write up! I have the 79 ZX dizzy and module in my 77 but when the module goes out I will be installing the HEI, much cheaper! Hell, I may just do it for a project 1 Link to comment Share on other sites More sharing options...
Zed Head Posted October 21, 2016 Share #47 Posted October 21, 2016 Cool. Thanks Chas. Much easier to find now. I "commented" in the Download area and linked back to this thread, for the back-story.. 1 Link to comment Share on other sites More sharing options...
Mike Posted October 21, 2016 Share #48 Posted October 21, 2016 On 10/20/2016 at 10:52 AM, EuroDat said: I made a tech article in the download section with the latest version. Thanks for contributing!! This looks awesome. You can also keep versions in the downloads area when you create new updates. Link to comment Share on other sites More sharing options...
