Recently Browsing 0
Late last year, I started developing an exhaust leak from the number 6 port which was... of course, broken off flush with the head. Probably has been broken for many years before I got the car. With the nice summer weather, I decided to replace the gasket & install all new high grade studs & bolts. Let PB Blaster go to work for a few days and went to work.
I removed the manifolds and used left hand drill bits to extract the broken studs. (number 1 was also broken off - discovered when i removed the manifolds) Number 1 backed out by the time I got up to about a 3/16th bit. Number 6 refused to comply, so I drilled it out and re-tapped for the stud.
Patience is definitely the key - accurate center punch mark, slow drill speed, cutting oil, don't overheat the small bit sizes.
Chased all the threads and prepped the head for the new gasket. All is looking very good so far.
Tomorrow, or the next day, will pick up the new stud & bolt hardware. Going to try and get grade 10.9 for the studs and 3 middle exhaust bolts. Grade 8 at least.
Also, have the main heat shield and some other stuff at Performance Coatings for ceramic exhaust coating - Chromex. Should be ready in 3 or 4 days.
Will be interesting if it has any impact on the minor heat soak issue I experience occasionally.... Will report back on that.
https://www.classiczcars.com/forums/topic/49603-manifold-stud-success/Share on other sites
