OK...not hoping to go over a very well worn post topic...
Leeroy
OK...I have a steering wheel, it is an original...I have been restoring it (polishing, restaining and laquering the rim), but I NEED a hrnpad...now I have a 260 2+2, and the steering wheel looks very different to others that I have seen! It has a polished steel set of bi-tri spoke (3 spokes, but each one is made of two thin ones with a horn button in between each of the three sets...ok, if you can understand what i mean, could you aid me in finding a kit? I have read that they're around $80, is that true of my wheel?
Thanks guys...haven't had to worry about it since I have an aftermarket wheel, but I want the original in (it looks way classier!).
Cheers ppl!
Thats the exact one...good work, I was wondering...oh well, first question, since I have never fitted it, does it fit up to the standard Z mounts? Second, if it does, where can I get the horn pad from?
Thanks guys, I was wondering why I had never seen it on a Z before!
Cheers ppl!
Hey Leeroy,
That's the wheel I'm running on my 260Z. Not to bad all in all, and for $20 from the local U-Pull-It wrecking yard I'm pretty happy :)
You should be able to find one on a 240K in a wrecking yard without too much difficulty.
Cheers,
Ross.
Was just looking at a magazine in the Newsagent and seen something similar advertised for $55.00
All you have to do is wander down to the Newsagent and look for the "Just Parts" mag which lists the parts in alphabetical order. Had a picture of it.
Got to be under D or N or S (narrowed down a bit) as these are the areas I looked at.
biker
  • Who's Online   1 Member, 0 Anonymous, 470 Guests (See full list)
