Picked up some original Nissan bearings and trying to confirm they are correct for a 1971 240Z.
Front wheel outer bearing 40215-P0100
Front wheel inner bearing 40210-A0100
Front wheel seals 40232-A0101
Thanks for your help, Kevin
Check out this handy Timken web site. Use the Cross Reference tab. "P" comes up as a transmission output shaft bearing.
"A" comes up as the Timken SET2 bearing, used for the wheel.
Timken Online Parts Catalog
You can also use the Application tab to input your vehicle. You'll see SET2 there.
  • 2 years later...
From Rock Auto:
Timken Set6 front inner
# LM67048 and Timken # LM6701
TIMKEN SET2 front outer
TIMKEN 1188S front inner seal
SKF BR2 front outer
SKF BR6 front inner
SKF 18864 {#40232A0101}  front seal
