Posted March 5, 200322 yr comment_28609 I can't figure this out. Everytime I brake hard, then come to a stop, my RPM's drop to the point of almost stalling. Then, after a few seconds, the RPM's pick back up. Could this weight transfer affect the fuel to the carbs?? Maybe not enough fuel in the float chamber?? The harder I brake the worse it gets. Anyone have an answer??? Link to comment https://www.classiczcars.com/forums/topic/4970-fuel-problem/ Share on other sites More sharing options...
March 5, 200322 yr comment_28618 Check the vacuum lines coming off the brake booster. It sounds like your problem. I had the same problem and I replaced the hoses and it fixed it. Link to comment https://www.classiczcars.com/forums/topic/4970-fuel-problem/#findComment-28618 Share on other sites More sharing options...
March 5, 200322 yr comment_28633 :classic: If that isn't it do check the float levels . Link to comment https://www.classiczcars.com/forums/topic/4970-fuel-problem/#findComment-28633 Share on other sites More sharing options...
March 5, 200322 yr comment_28707 I have something like this too. Whenever I make a hard U turn to the left, I mean squealing the tires U turn. My car wants to quit, rpm's drop and a few seconds later she comes back to normal.????I never thought much of it. I just quit making those quick U turns. Link to comment https://www.classiczcars.com/forums/topic/4970-fuel-problem/#findComment-28707 Share on other sites More sharing options...
March 5, 200322 yr comment_28730 :classic: Ed, how do you get the tires to squeal on ICE ? read above post. Gary Or is this tire noise from memory ? Link to comment https://www.classiczcars.com/forums/topic/4970-fuel-problem/#findComment-28730 Share on other sites More sharing options...
March 5, 200322 yr comment_28737 Ed ,Does your flavor Z have power steering? Link to comment https://www.classiczcars.com/forums/topic/4970-fuel-problem/#findComment-28737 Share on other sites More sharing options...
March 5, 200322 yr comment_28738 Unfortunately it is from memory. My Zed hasn't tasted pavement since November:cry: Link to comment https://www.classiczcars.com/forums/topic/4970-fuel-problem/#findComment-28738 Share on other sites More sharing options...
