If you don't know about the brakes on your new classic Z and it has a wobble in the steering wheel around 30 mph then you should try this. I replaced the inner and outer front wheel bearings, had the rotors turned and new grease packed in the hub. $50 to go from driving what felt liked a cooked spaghetti noodle to an uncooked noodle, stiffer without the shakes.
Here's the info;
http://www.atlanticz.ca/zclub/techtips/frontwheelbearings/index.html
http://www.classiczcars.com/forums/suspension-steering-s30/52750-wheel-bearing-race-removal.html
Edited by siteunseen
https://www.classiczcars.com/forums/topic/49723-new-owners-of-zs-this-helps/
