Original A/C units
grannyknot
Mine was an ARA unit installed by the dealer. Big, honkin' York compressor mounted on a frame that surrounded the fuel pump. Altho the A/C is no longer installed, I've kept the console switch and the evaporator unit that mounted on the heater box in case I decide to put A/C back in the car.
Factory air was available in the 1969-73 RHD Z-L models as an option, but i've only ever seen 2 installations, so it must not have been a very common option. I'd imagine it'd be straightforward to fit it to an export 240Z, if you could find the parts.
  • Who's Online   2 Members, 0 Anonymous, 385 Guests (See full list)
