Posted August 12, 201410 yr comment_453211 ...that came with a 2.4 motor. Going to get it Friday. Edited August 12, 201410 yr by siteunseen Link to comment https://www.classiczcars.com/forums/topic/49815-bought-some-carburetors/ Share on other sites More sharing options...
August 12, 201410 yr comment_453220 And a header! Link to comment https://www.classiczcars.com/forums/topic/49815-bought-some-carburetors/#findComment-453220 Share on other sites More sharing options...
August 19, 201410 yr Author comment_453723 The end of the rainbow Nice clean early E88, small valves Odd looking ports on header runners Link to comment https://www.classiczcars.com/forums/topic/49815-bought-some-carburetors/#findComment-453723 Share on other sites More sharing options...
August 19, 201410 yr comment_453725 What year motor? I would be just as excited about an early e-88!! The cam looks good from here. Link to comment https://www.classiczcars.com/forums/topic/49815-bought-some-carburetors/#findComment-453725 Share on other sites More sharing options...
August 19, 201410 yr comment_453726 The bungs inside the header manifold may whistle. Consider plugging then grinding smooth. Link to comment https://www.classiczcars.com/forums/topic/49815-bought-some-carburetors/#findComment-453726 Share on other sites More sharing options...
August 19, 201410 yr Author comment_453730 Blue said: The bungs inside the header manifold may whistle. Consider plugging then grinding smooth.That header's too far gone.What would those bungs have been for?Thanks. Link to comment https://www.classiczcars.com/forums/topic/49815-bought-some-carburetors/#findComment-453730 Share on other sites More sharing options...
August 19, 201410 yr Author comment_453731 madkaw said: What year motor? I would be just as excited about an early e-88!! The cam looks good from here.It's a '73 but the head has been serviced before. Also had the round mouth carbs installed when the head was done. It has one of those "heat buttons" siliconed on the end casting plug that has "Birmingham CHS- VOID IF REMOVED". Link to comment https://www.classiczcars.com/forums/topic/49815-bought-some-carburetors/#findComment-453731 Share on other sites More sharing options...
August 19, 201410 yr comment_453738 siteunseen said: That header's too far gone.What would those bungs have been for?Thanks.Smog pump emission system: pumps fresh air into the exhaust stream to dilute it and to help with removing some harmful gases by chemical reaction with the air. Link to comment https://www.classiczcars.com/forums/topic/49815-bought-some-carburetors/#findComment-453738 Share on other sites More sharing options...
August 20, 201410 yr comment_453818 siteunseen said: It's a '73 but the head has been serviced before. Also had the round mouth carbs installed when the head was done. It has one of those "heat buttons" siliconed on the end casting plug that has "Birmingham CHS- VOID IF REMOVED".73 E88 has the emmision chambers. I think they changed around July or August 72. There was an E88 as good as identical to the E31, then they modified it and dropped the cr a little around September 71.lt is suggested that the way the E88 is stamped (type font) may be related to the different versions. I have read the the US version are different to the other markets as well after August 72. Whether that is true or not mmmm Im no expert on E88s and there is a lot of woffle on the interent.Like madkawsaid, that cam looks really nice. Cant be too long ago that it was rebuild by "Birmingham CylinderHead Service".Chas Link to comment https://www.classiczcars.com/forums/topic/49815-bought-some-carburetors/#findComment-453818 Share on other sites More sharing options...
August 20, 201410 yr Author comment_453833 I'm beginning to feel a little like Jeffery Dahmer, collecting heads.I've got an E313 E88s1 N421 N47and a P793 of those are on my cars. TOOT TOOT! Link to comment https://www.classiczcars.com/forums/topic/49815-bought-some-carburetors/#findComment-453833 Share on other sites More sharing options...
August 20, 201410 yr comment_453841 It's possible you may have some long lost relatives in the Amazon! Link to comment https://www.classiczcars.com/forums/topic/49815-bought-some-carburetors/#findComment-453841 Share on other sites More sharing options...
