Posted August 19, 201410 yr comment_453752 The temperature in my 240z is not Reading correct and i was thinking now that the car has 2 days of not been cranked to remove the temperature sending unit on my car, clean it with a brush and contact cleaner and reinstall it back again. Is there anything i should be aware? i.e. using a dialectric grease or pipe tape? any precautions i should take when removing and installing it back? I bought a new one on ebay and the mechanic says it does not fit. I thought these temp sending units were standard for 1970-1983 Zs?Please advise. Link to comment https://www.classiczcars.com/forums/topic/49878-removing-cleaning-and-reinstalling-a-water-temperature-sending-unit-on-a-datsun-240z/ Share on other sites More sharing options...
August 19, 201410 yr comment_453754 The temperature in my 240z is not Reading correct and i was thinking now that the car has 2 days of not been cranked to remove the temperature sending unit on my car, clean it with a brush and contact cleaner and reinstall it back again. Is there anything i should be aware? i.e. using a dialectric grease or pipe tape? any precautions i should take when removing and installing it back? I bought a new one on ebay and the mechanic says it does not fit. I thought these temp sending units were standard for 1970-1983 Zs?Please advise.What doesn't fit - the temp sender or the retaining nut?Dennis Link to comment https://www.classiczcars.com/forums/topic/49878-removing-cleaning-and-reinstalling-a-water-temperature-sending-unit-on-a-datsun-240z/#findComment-453754 Share on other sites More sharing options...
August 20, 201410 yr Author comment_453814 Last night i over tightened the retaining nut and blew off the thread? Now what do i do? I will need to order a new housing or can i fix this one? Link to comment https://www.classiczcars.com/forums/topic/49878-removing-cleaning-and-reinstalling-a-water-temperature-sending-unit-on-a-datsun-240z/#findComment-453814 Share on other sites More sharing options...
