Posted September 6, 201410 yr comment_454797 I've been addressing my new toe '72's issues one at a time, starting with brakes. First job was a new reman brake booster from MSA which made a huge difference. Second was to address break noise that occurred with slight pressure. Took off the wheels, pulled pads and shims, cleaned them up applied grase between the pad and shim, put them back the way I found them ( lots of pad left). Theth were much better but they still would "sing" a little with light pressure. Did a search and stumbled across a diagram that shows y shims are upside down.The were and are in in an "L" shaped position with the arrow on the shim pointing down. Could this be causing my continued noise?:tapemouth Link to comment https://www.classiczcars.com/forums/topic/49993-could-my-brake-noise-be-because-front-pad-shims-are-in-upside-down/ Share on other sites More sharing options...
September 6, 201410 yr comment_454799 I do know the shims make a difference. I thought the arrow pointed in the direction of rotation. Which appears to be up.Datsun 240Z/260Z/280Z Front Brake (Disc Brake) Link to comment https://www.classiczcars.com/forums/topic/49993-could-my-brake-noise-be-because-front-pad-shims-are-in-upside-down/#findComment-454799 Share on other sites More sharing options...
September 6, 201410 yr comment_454809 The arrows should be pointing in the direction of forward wheel rotation, and I've also found from experience that they do matter.I had an intermittend brake squeal and when I pulled my pads, I found my PO had installed those shims backwards. I flipped them around and my squeal hasn't come back since. I was thrilled it was that simple. Link to comment https://www.classiczcars.com/forums/topic/49993-could-my-brake-noise-be-because-front-pad-shims-are-in-upside-down/#findComment-454809 Share on other sites More sharing options...
September 7, 201410 yr Author comment_454834 Took half an our this evening to jack up the car, place the jack stands, wheels off, shims switched and flipped with the arrow pointed the right directions. Half hour test drive with lots of stop and go with no noise! Very pleased with easy fixes. Much more confident with my brakes.thanks! Link to comment https://www.classiczcars.com/forums/topic/49993-could-my-brake-noise-be-because-front-pad-shims-are-in-upside-down/#findComment-454834 Share on other sites More sharing options...
September 7, 201410 yr comment_454849 Excellent. Sounds like you an I had the same issue... We needed to turn our squeal shims into anti-squeal shims. Link to comment https://www.classiczcars.com/forums/topic/49993-could-my-brake-noise-be-because-front-pad-shims-are-in-upside-down/#findComment-454849 Share on other sites More sharing options...
