Posted September 10, 201410 yr comment_455078 GVWR for my early 260z (with Factory a/c is listed at 3010lbs - figure ~ 2700lbs curb). I would like to get her a little lighter. I will start with the low hanging fruit - a/c is in-effective so I'm going to start with removing that. I figure the compressor alone must weigh ~ 30lbs ! any other suggestions ? Link to comment https://www.classiczcars.com/forums/topic/50022-my-z-needs-to-go-on-a-diet/ Share on other sites More sharing options...
September 10, 201410 yr comment_455100 You'll need to tell us how light you want to go. Myself I've always wanted to have a stripped Z for the street but loving to drive a Z year round, a heater is a must & the list goes on. I'm torn between fun & creature comforts. You'll have to consider what you want to keep depending on your wants & needs. Mark Link to comment https://www.classiczcars.com/forums/topic/50022-my-z-needs-to-go-on-a-diet/#findComment-455100 Share on other sites More sharing options...
September 10, 201410 yr comment_455171 My first suggestion: don't use GVWR as a guide to curb weight unless you also have the maximum load capacity on hand (GVWR=Curb Weight + Max Load).An early 260Z weighs in at just over 2400lb, confirmed on actual scales and not internet numbers. Link to comment https://www.classiczcars.com/forums/topic/50022-my-z-needs-to-go-on-a-diet/#findComment-455171 Share on other sites More sharing options...
September 10, 201410 yr comment_455175 Swap to early style fiberglass bumpers, ditching the stock bumper brackets. You'll have to fabricate brackets for the bumpers. Here's a link to how I did it for stainless steel bumpers: 260Z Air Dam and Front Bumper | Fiddling With Z CarsSwap to carbon fiber hood and hatch.Ditch the spare tire. Link to comment https://www.classiczcars.com/forums/topic/50022-my-z-needs-to-go-on-a-diet/#findComment-455175 Share on other sites More sharing options...
September 10, 201410 yr comment_455179 if you do decide to ditch the a/c, there are a couple small parts i could use. Link to comment https://www.classiczcars.com/forums/topic/50022-my-z-needs-to-go-on-a-diet/#findComment-455179 Share on other sites More sharing options...
September 11, 201410 yr Author comment_455185 thanks for your reply's. LeonV - that 2400lbs # is for a stock 260z with factory A/C ? Link to comment https://www.classiczcars.com/forums/topic/50022-my-z-needs-to-go-on-a-diet/#findComment-455185 Share on other sites More sharing options...
September 11, 201410 yr comment_455199 thanks for your reply's. LeonV - that 2400lbs # is for a stock 260z with factory A/C ?Let's call it 2450lb with AC. There is no way an early 260Z weighs in at 2700lb without Professor Klump in the driver's seat. Link to comment https://www.classiczcars.com/forums/topic/50022-my-z-needs-to-go-on-a-diet/#findComment-455199 Share on other sites More sharing options...
