JR Ohio Posted September 10, 2014 Share #1 Posted September 10, 2014 Looks like I will need to put a helicoil in at least one of my crank/flywheel holes. They are not out yet, so I don't know the size and thread. I am sure there are lots of smart folks out there that can tip me off so I can order the right parts in advance. Also I will need new flywheel bolts. So any advice on buying those would be appreciated also. Thank you for your knowledge and help! John Link to comment Share on other sites More sharing options...
Zed Head Posted September 10, 2014 Share #2 Posted September 10, 2014 (edited) Your dealer might be able to get the bolts.BOLT-FLYWH :: Nissan Parts, NISMO and Nissan Accessories - Courtesyparts.comI had some bolts and old lug nuts in the garage. The flywheel bolt is the same thread as a lug nut. 12mm x 1.25. Edited September 10, 2014 by Zed Head Link to comment Share on other sites More sharing options...
JR Ohio Posted September 10, 2014 Author Share #3 Posted September 10, 2014 Thanks Zed Head! I'll order some new ones and try to find helicoils to fix the bad guys!Any tips on where to get them?John Link to comment Share on other sites More sharing options...
Pop's Z Posted September 10, 2014 Share #4 Posted September 10, 2014 I'm not sure if I would want to put helicoils in my crankshaft. It might be very difficult to install them, too. Perhaps one of the truly mechanically inclined would chime in...zcars, John Mortenson, Carl Beck? Admittedly, I am not a professional mechanic. It just gives me pause.Cheers, Mike Link to comment Share on other sites More sharing options...
Pop's Z Posted September 10, 2014 Share #5 Posted September 10, 2014 Just another quick thought...talk to a good machine shop about the helicoil in the crankshaft idea and see what they think about it,Cheers, Mike Link to comment Share on other sites More sharing options...
JR Ohio Posted September 15, 2014 Author Share #6 Posted September 15, 2014 Good news! The bolt was stripped! Left remnants of the bolt in the threads and the local hardware was open today (sunday) and had the proper tap! Flywheel off, threads cleaned out, replacing the rear seal and taking the flywheel to be resurfaced tomorrow!Whew! Thanks my good friend that helped my sooo much, I am a smiling Z guy again! Link to comment Share on other sites More sharing options...
