Posted September 14, 201410 yr comment_455372 I have a 1973 240Z with an L24 Engine. I am looking for a pair of side draft throttle body electronic fuel injectors that will will bolt on directly in place of the carburetors. I would like the electronic control unit to be fully tune able. Does anyone know where I can purchase something like this? Thank you for any help and guidance.SJC240 Link to comment https://www.classiczcars.com/forums/topic/50051-need-guidance-looking-for-throttle-body-electronic-fuel-injectors/ Share on other sites More sharing options...
September 14, 201410 yr comment_455387 I have seen this system and I am tempted to try it, but I don't know anything about this company, and have no references good, or bad. It is just something that I have seen:Patton MachineI think that others on this site have mentioned it before. Link to comment https://www.classiczcars.com/forums/topic/50051-need-guidance-looking-for-throttle-body-electronic-fuel-injectors/#findComment-455387 Share on other sites More sharing options...
September 14, 201410 yr Author comment_455391 Thank You, I appreciate your help. Link to comment https://www.classiczcars.com/forums/topic/50051-need-guidance-looking-for-throttle-body-electronic-fuel-injectors/#findComment-455391 Share on other sites More sharing options...
September 14, 201410 yr comment_455399 That's a pretty neat set-up. Are the SUs on Datsuns HS8 or HD8? I've never seen those numbers but according to Wikipedia I think they're HSs.Thanks for sharing that website, I learned something new to me. Link to comment https://www.classiczcars.com/forums/topic/50051-need-guidance-looking-for-throttle-body-electronic-fuel-injectors/#findComment-455399 Share on other sites More sharing options...
September 14, 201410 yr comment_455423 siteunseen said: That's a pretty neat set-up. Are the SUs on Datsuns HS8 or HD8? I've never seen those numbers but according to Wikipedia I think they're HSs.Thanks for sharing that website, I learned something new to me.None of the above. The "SUs" that came on Z-cars aren't actually SUs, they are Hitachi HJG46W (USA round tops) or HMB46W (USA flat tops), the design being licensed by SU. They're colloquially referred to as SUs because that's where the design came from, Nissan called them both SUs and SU-type in the FSMs. Link to comment https://www.classiczcars.com/forums/topic/50051-need-guidance-looking-for-throttle-body-electronic-fuel-injectors/#findComment-455423 Share on other sites More sharing options...
September 14, 201410 yr comment_455424 Back on point, I've heard good things about the Patton Machine stuff and Megasquirt is a great way to go for a standalone. This is not a plug-and-play project. There is much research ahead of you... Link to comment https://www.classiczcars.com/forums/topic/50051-need-guidance-looking-for-throttle-body-electronic-fuel-injectors/#findComment-455424 Share on other sites More sharing options...
September 15, 201410 yr comment_455453 His website indicates that it is plug and play for his system. Reading the installation instructions and the parts information, the early 240Z is listed among the applications. Link to comment https://www.classiczcars.com/forums/topic/50051-need-guidance-looking-for-throttle-body-electronic-fuel-injectors/#findComment-455453 Share on other sites More sharing options...
September 15, 201410 yr comment_455471 Zup said: His website indicates that it is plug and play for his system. Reading the installation instructions and the parts information, the early 240Z is listed among the applications.Sure, you can bolt on throttle bodies and having something nice to look at, but to make it all actually work is certainly not plug-and-play... Link to comment https://www.classiczcars.com/forums/topic/50051-need-guidance-looking-for-throttle-body-electronic-fuel-injectors/#findComment-455471 Share on other sites More sharing options...
September 15, 201410 yr comment_455485 [joke]Maybe he means you plug it in and then play with it for months trying to get the tuning right.[/joke] :paranoid: Link to comment https://www.classiczcars.com/forums/topic/50051-need-guidance-looking-for-throttle-body-electronic-fuel-injectors/#findComment-455485 Share on other sites More sharing options...
September 15, 201410 yr comment_455495 I thought "plug and play" was a marital tool. :stupid: Link to comment https://www.classiczcars.com/forums/topic/50051-need-guidance-looking-for-throttle-body-electronic-fuel-injectors/#findComment-455495 Share on other sites More sharing options...
