Performance Q's: How to get the most out of my L24
metalmonkey47
Stock N47 cam. Is there a difference between different L-6 cams other then internal/external oiling?
Yes. The A cam tends to make power at a higher RPM range than the C cam. My experience is the A cam will pull to 6k or so, the C cam pulls to about 5k. I can't say one will make more total power than the other but the higher RPM range of the A cam could feel like more just due to the RPM range difference.
