The manual states I should have them. It does not state how they are operated.
The turn signal stalk does not move forward or back. I fear to break it. But if that is how the operate, I may try pushing a little harder.
Cheers
Edited by HuD 91gt
Yes, it does. See page 14 of the owners manual.
The stock switch does pull back. Look at the parts manual at CarPartsManual.com - Online Parts Catalogs for Classic Cars. Find the turn signal switch and see if it looks different from what you have. If it does look different, I suggest you post a picture.
man, i have SO been there....
actually started tearing apart wiring and installing additional grounds before accidentally bumping the blinker stalk while upside down under the steering column trying to remove my cover and tear apart the switch...
so your'e NOT the only dummy :)
