Posted October 12, 201410 yr comment_456903 I need a little help getting the rear suspension put back together on my 1972 240z. I took off the old front differential insulator, seen below, which has a center bolt that is fastened with a washer and nut. The new insulator, seen below, has a rubber center section where the bolt should be. Is this the right insulator? How does it attach to the cross member? Also, this project has taken me a few weeks as I got derailed with the rear control arm pin for a couple of weeks. Now my memory is fuzzy and I can't remember how I disassembled the cross member. There are two bolt holes on either side of the center hole in the front cross member. (see below circled in yellow) I don't remember anything attached here when I disassembled the cross member but it's been awhile. What attaches to these holes? Thanks for the help. Rick Link to comment https://www.classiczcars.com/forums/topic/50206-differential-insulator-mount/ Share on other sites More sharing options...
October 12, 201410 yr comment_456906 I'm guessing that there's a stud under that rubber. Maybe someone missed a step during manufacturing and didn't clean up the leakage. Or somebody forgot to put the bolt in but poured the rubber anyway. The two holes are probably for the big ugly vibration damper that Nissan added to later Z's. Link to comment https://www.classiczcars.com/forums/topic/50206-differential-insulator-mount/#findComment-456906 Share on other sites More sharing options...
October 12, 201410 yr comment_456909 You're going to feel silly when you pull that rubber protector off the threads...The two threaded holes in the crossmember were used for an optional weight that was hung off the crossmember to counteract vibration. Nothing for you to do. Edited October 12, 201410 yr by zKars Link to comment https://www.classiczcars.com/forums/topic/50206-differential-insulator-mount/#findComment-456909 Share on other sites More sharing options...
October 12, 201410 yr Author comment_456911 Eureka!! Under the rubber cover is a nice shiny bolt. The rubber cover was on pretty tight so I had to grab it with some pliers. I do, in fact, feel silly. I'd like to lie and say this was the first time I was an idiot...but sadly, that would not be true. Thanks for the help. Link to comment https://www.classiczcars.com/forums/topic/50206-differential-insulator-mount/#findComment-456911 Share on other sites More sharing options...
October 12, 201410 yr comment_456916 We've all been there welcome to the club! Link to comment https://www.classiczcars.com/forums/topic/50206-differential-insulator-mount/#findComment-456916 Share on other sites More sharing options...
October 12, 201410 yr comment_456922 The only way anyone has the right to poke fun at someone elses mistakes, is if they have a degree from the university of doing silly things. As anyone who has worked with me knows, I have a PhD from there. Link to comment https://www.classiczcars.com/forums/topic/50206-differential-insulator-mount/#findComment-456922 Share on other sites More sharing options...
October 12, 201410 yr comment_456925 We have a satellite U.D.S.T school down here. I put my pistons in the block 3 times. Notch forward, dimple up, gap at 10 2 and 4 etc. I used my PHD Saturday planting some Knockout Roses for a neighbor. She paid me back. Link to comment https://www.classiczcars.com/forums/topic/50206-differential-insulator-mount/#findComment-456925 Share on other sites More sharing options...
October 13, 201410 yr comment_456931 I studied at the Sheet Harbour Institute of Technology. Link to comment https://www.classiczcars.com/forums/topic/50206-differential-insulator-mount/#findComment-456931 Share on other sites More sharing options...
October 13, 201410 yr comment_456942 As I'm fond of saying: "Good judgment comes from experience, and experience comes from poor judgment". Looking backward, I must be very experienced... Link to comment https://www.classiczcars.com/forums/topic/50206-differential-insulator-mount/#findComment-456942 Share on other sites More sharing options...
October 13, 201410 yr comment_456959 I studied at the Sheet Harbour Institute of Technology.That's so cool! I did some distance learning from the same institute.I've got my Sheet Harbour Institute of Technology Hardware Engineer Associates Degree. Link to comment https://www.classiczcars.com/forums/topic/50206-differential-insulator-mount/#findComment-456959 Share on other sites More sharing options...
October 13, 201410 yr comment_456964 An old friend says, "Experience is what you get when you didn't get what you wanted"................Cheers, Mike Link to comment https://www.classiczcars.com/forums/topic/50206-differential-insulator-mount/#findComment-456964 Share on other sites More sharing options...
October 13, 201410 yr comment_456967 My favorite way of describing these kind of things is "tuition" ie the cost of learning at one of these institutionsCharles Link to comment https://www.classiczcars.com/forums/topic/50206-differential-insulator-mount/#findComment-456967 Share on other sites More sharing options...
