November 4, 20177 yr Author comment_534108 36 minutes ago, Namerow said: Would that fit in a P1800? No, but this would and keep with the Nordic theme going, https://www.engineswapdepot.com/?p=18648 Link to comment https://www.classiczcars.com/forums/topic/50240-thinking-about-installing-an-bmw-m6-engine-in-my-z/?&page=52#findComment-534108 Share on other sites More sharing options...
November 4, 20177 yr comment_534111 Old school way to make 1500 HP on a 1.5 litre 4 cylinder: https://racingotaku.wordpress.com/2009/06/08/best-f1-engine/ BMW Too! Link to comment https://www.classiczcars.com/forums/topic/50240-thinking-about-installing-an-bmw-m6-engine-in-my-z/?&page=52#findComment-534111 Share on other sites More sharing options...
November 4, 20177 yr comment_534117 2 hours ago, grannyknot said: his would and keep with the Nordic theme going "The engine costs €120,000 ($140,490)..." I'm out. Link to comment https://www.classiczcars.com/forums/topic/50240-thinking-about-installing-an-bmw-m6-engine-in-my-z/?&page=52#findComment-534117 Share on other sites More sharing options...
November 4, 20177 yr comment_534148 On 11/3/2017 at 7:11 PM, grannyknot said: This is an S54Â M engine 2001 - 2006, the last of the big straight sixes from bmw before they started slapping turbos on everything. I had an 01 M roadster for a little while. It was silly fast. I love that motor. It is one of my favorites, so sexy... Link to comment https://www.classiczcars.com/forums/topic/50240-thinking-about-installing-an-bmw-m6-engine-in-my-z/?&page=52#findComment-534148 Share on other sites More sharing options...
November 10, 20177 yr Author comment_534561 There is a site that is dedicated to engine swaps, he has thousands of write ups about the projects, some are brilliant, some will make you winch. He just did a write up on my car, https://www.engineswapdepot.com/?p=18991 Thanks to my good buddy @Careless I picked up an orphan that needed a home... it was also free, BMW 4.0L V8 Haven't a clue what I'm going to do with it but the price was right.   Link to comment https://www.classiczcars.com/forums/topic/50240-thinking-about-installing-an-bmw-m6-engine-in-my-z/?&page=52#findComment-534561 Share on other sites More sharing options...
February 18, 20187 yr Author comment_542673 The last oil analysis said there was a lot of sand and dirt in the oil so I got rid of the K&N filter and pick up a proper paper filter from a 2008 Mustang, that should take care of that. I never did like the spliter/stiffener I made last year, the piece of aluminum wasn't wide enough and looked kinda weird, So I picked up a full size piece and started again, I'm going BOSOZOKU ! Made up some new clam shell pieces to clamp onto the lower lip of the air dam, Link to comment https://www.classiczcars.com/forums/topic/50240-thinking-about-installing-an-bmw-m6-engine-in-my-z/?&page=52#findComment-542673 Share on other sites More sharing options...
February 18, 20187 yr comment_542679 Very nice! Link to comment https://www.classiczcars.com/forums/topic/50240-thinking-about-installing-an-bmw-m6-engine-in-my-z/?&page=52#findComment-542679 Share on other sites More sharing options...
August 25, 20186 yr comment_556151 https://columbusga.craigslist.org/cto/d/1971-datsun-240z-powered-by/6673299837.html M3 powered 240. Link to comment https://www.classiczcars.com/forums/topic/50240-thinking-about-installing-an-bmw-m6-engine-in-my-z/?&page=52#findComment-556151 Share on other sites More sharing options...
August 25, 20186 yr comment_556153 The last oil analysis said there was a lot of sand and dirt in the oil so I got rid of the K&N filter and pick up a proper paper filter from a 2008 Mustang, that should take care of that.I never did like the spliter/stiffener I made last year, the piece of aluminum wasn't wide enough and looked kinda weird, So I picked up a full size piece and started again, I'm going BOSOZOKU !Made up some new clam shell pieces to clamp onto the lower lip of the air dam, I think I would try and replace those bolt, nut and lockwasher fasteners to a rivnut in the splitter. And some shorter bolts... Link to comment https://www.classiczcars.com/forums/topic/50240-thinking-about-installing-an-bmw-m6-engine-in-my-z/?&page=52#findComment-556153 Share on other sites More sharing options...
August 25, 20186 yr Author comment_556175 6 hours ago, siteunseen said: https://columbusga.craigslist.org/cto/d/1971-datsun-240z-powered-by/6673299837.html M3 powered 240. Too bad he went that far and didn't bother to finish it, sounds like everything other than the paint needs sorting out. 6 hours ago, wheee! said: I think I would try and replace those bolt, nut and lockwasher fasteners to a rivnut in the splitter. And some shorter bolts...  So you mean finish it properly? Maybe I'll get to it one of these days Link to comment https://www.classiczcars.com/forums/topic/50240-thinking-about-installing-an-bmw-m6-engine-in-my-z/?&page=52#findComment-556175 Share on other sites More sharing options...
December 15, 20195 yr Author Popular Post comment_589288 Okay so I'm dragging this one back out because big changes are happening, the S38 engine experiment was a success in many ways and in a few ways not so much. So I pulled it and sold it on BaT, wonderful engine but it is just not supported anymore. I have rebuilt the e46 S54 M3 engine and that will be the new power plant. So far the swap is going well, the engine is in, transmission and diff are lined up and the custom driveshaft is being built right now. I should have it back in a week, next step is to have the BMW ECU re programed to eliminate all the extras that aren't needed and set to wiring it up. I finally got around to making the top of the radiator support removable, considering how often the engines come and go it will be a big help, just have smooth it out, do some filling/sanding and try to match the paint. The original intake airbox sticks right out into the shock tower and also had problems with the #1 and #6 cylinders having uneven access to air so I have opened it up will try to fabricate a custom funnel to the air filter.   Edited December 15, 20195 yr by grannyknot Link to comment https://www.classiczcars.com/forums/topic/50240-thinking-about-installing-an-bmw-m6-engine-in-my-z/?&page=52#findComment-589288 Share on other sites More sharing options...
December 15, 20195 yr comment_589292 WOW... you amaze! Link to comment https://www.classiczcars.com/forums/topic/50240-thinking-about-installing-an-bmw-m6-engine-in-my-z/?&page=52#findComment-589292 Share on other sites More sharing options...
