Posted November 9, 201410 yr comment_458337 No power to my fuel pump, No power to my injectors. WHY ?? Link to comment https://www.classiczcars.com/forums/topic/50382-my-z-is-not-runningwhy/ Share on other sites More sharing options...
November 9, 201410 yr comment_458339 There is a fusible link on the +pos battery terminal cable. Check to see that it is plugged in.Most 280z problems are simply corroded wire connections.This page is a good starting point: http://www.atlanticz.ca/zclub/techtips/electricalconnections/index.html Link to comment https://www.classiczcars.com/forums/topic/50382-my-z-is-not-runningwhy/#findComment-458339 Share on other sites More sharing options...
November 9, 201410 yr comment_458340 A little bit of history on the car would be nice also. Could help us help you. Link to comment https://www.classiczcars.com/forums/topic/50382-my-z-is-not-runningwhy/#findComment-458340 Share on other sites More sharing options...
