New Look
zhead240
Do you like the new website?
27 members have voted
  1. 1. Do you like the new website design?
    • Yes
      7
    • It needs some more work
      11
    • No
      5
    • Unsure yet
      4
I cannot access from iPhone anymore. It shows blank page.
I'm still having hard time to find out where to click to see latest post on this web site.
Also, I'm confused where should I ask for those kind of web site related question? Which forum?
Thanks,
Takashi
Text is now black, I actually agree that it's much better as black.  Somehow I didn't notice but this is a lot better.
Made a few tonight.  And, for you I increased the font to the 14pt size.  Both of these ideas are actually very good ideas.  I couldn't find the font size quickly but after a bit of code searching I found it.
m
Much Better font size and color.  But will the quoted text be larger as well? In the Posts above it seems to still be very small and light.
Carl B.
First Edit: cub
I guess my question was answered - in my own Post. LOL  Can you work on the quoted text size and color as well?   Also I don't see the hypertext that used to lead and follow the quoted text.  Is it possible to still break quoted text into two or more blocks; and comment on them individually?  I'll try that next..
CJB - - I agree.. it is much better.
CJB - - - I appreciate that - even if it wasn't for me
I'll think about a solution on the theme...  maybe what we need is a few to pick from and then vote on the final design.  I don't really want to support more than a single theme because changes can be a bitch...  (this font thing is a good example)
Anyway, good ideas, keep 'em coming.
m
Here I tried to break the quoted text into blocks - like we used to be able to do. I'm afraid that inserting carriage returns doesn't stop the quoted text - - but allows you to edit it. Might not be a good thing..
Carl
Text is now black, I hope you'll stop complaining now.
Made a few tonight.  And, for you I increased the font to the 14pt size.  Now don't ask me for anything else.
m
OK - see what I mean?  I made a few edits to your original Post...
I was able to increase the font size in the Reply Editor - I'll see if it shows up that way.
FWIW,
Carl B.
Edit #1 cjb - - OK the font size of the quoted text was increased - - only it is still somewhat "grayed out"..
Carl, looks like you can click on the little light switch in the upper left of the edit box.  It will toggle between WYSIWYG mode and the "code" mode.  You will be able to split the single author quotes using the quote command. I added a split here as an example.  If you don't like writing in code mode, you can add your splits and then toggle back and forth.
You've always been able to edit someone else's quote, even in the old software, unfortunately.
I'm looking into the quoted text issue today.
Hi Takashi, sorry I broke the iPhone theme, will fix today.  You can post all website questions to us in the website development forum here:  http://www.classiczcars.com/forum/62-our-website/
What's "View New Contents" button do?
If you select it, you can see all of the new content and forum posts.  It doesn't always show you the forum content by default (yet) so sometimes you have to pick "forum" from the left side.
Hi Mike - thanks. That icon was so small I couldn't see what it was. Now that I know - I can use it. LOL
Code Mode works for me.
You could? I guess I never tried that before. I was just taking this new S/W for a spin.. to learn how it was going to work - and provide feedback
Great - thanks..
Thanks Mike for the support!
I really appreciate your hard work!
Regards,
Takashi
When I checked FORUM on the left under NEW CONTENT then bookmarked that page, it goes straight to all the newest post when I select Classic Z cars from my Bookmarks.  It's the same now as the older version, opens with NEW TOPICS.
I too think we could use more colors than grey though.  It all kind of blends in, sorta bland looking.
