I was more curious than anything, it seem to be negelected.
I have used diodes in the past to reduce the back emf. Don't know if they still call it that these days. I know diodes are less reliable, but I have never had one fail on me yet.
Maybe I should have said "normal" instead of "servicable" relay since most relays don't have this voltage spike limiting function.
I believe the resistor is between 600 - 800 ohm which wouln't draw much anyway.
  • 3 weeks later...
If you wanted to add fog lamps or driving lamps, which should only come on with the headlights, you need two switched +12V lies from the headlamp switch to power some relays.  where would a good place to get the switch +12V?  You would put in one or two extra wires that would operate the relays for the extra lamps.
  • 6 months later...
ryn004,
What's the purpose for? Is there any advantage?
Adding headlight relay close to battery will increase  brightness of headlight. Same to starter relay.
But, I don't see any advantage to re-wiring fuel pump, EFI relay.
