I need the following parts for my 240z but with Premium high quality standards:
Urethane Bushing kit
Steering Rack boots
Crankcase gasket or ENgine overhaul gasket kit
Rear Main seal / crankshaft
Front and Rear transmission Seal
Front cover gasket engine
Rear differential cover seal
Rear differential Seal
Should i purchase these seals and bushings in Black Dragon or should i really invest on high end part supplier? if so which one carries all these parts.
I use the OEM stuff, mostly because it doen't cost mush more than the others and I know the quality is ok. Engine gasket kits might be a different story and the performance aftermarket kits may be better.
Don't have much experience onthe PU bushing kits. I bought minefrom energy suspension and a TC rod kit from MSA.
BTW I didn't use all the kit. I left the transmission mount bracket bushes as is and some people recommend leaving the mustache bar alone if the car is a daily driver or just street use. Changing these tend to make the ride harsh.
Chas
I read good reviews on Ishino engine gasket seals. They are available on Amazon and Partgeeks which has a better Price.
Any advice on these seals i have mentioned initally.
  • 1 month later...
I just received a complete engine gasket kit from Rock-auto, it is a Felpro kit. The reason I like Felpro is that no seals are cork. The kit is 20$ more than the others, but much better in my opinion. The HG seems to be a newer design and looks good.
  • 4 weeks later...
Just finished installing these urethane bushings. Very high quality. The kit came with every rubber part on the suspension except the front dif mount but mine was okay anyway. Felpro is a good gasket. Used them for years in drag racing, no issues. They're usually available at a local parts house or easy to order next day and the price is fair.
