Posted November 18, 201410 yr comment_458786 What does the knob next to the front hatch opener do? Also what does the knob under the dash on the passenger side of the car do? Link to comment https://www.classiczcars.com/forums/topic/50439-newbie-280z-question/ Share on other sites More sharing options...
November 18, 201410 yr comment_458791 Probably fresh air vent actuators. Pull on them. Link to comment https://www.classiczcars.com/forums/topic/50439-newbie-280z-question/#findComment-458791 Share on other sites More sharing options...
November 18, 201410 yr Author comment_458792 Also what's the dial that has open/close on it do? Link to comment https://www.classiczcars.com/forums/topic/50439-newbie-280z-question/#findComment-458792 Share on other sites More sharing options...
November 18, 201410 yr comment_458793 The dial does not actually do anything. It only indicates the state of something. Probably something that opens and closes. Link to comment https://www.classiczcars.com/forums/topic/50439-newbie-280z-question/#findComment-458793 Share on other sites More sharing options...
November 18, 201410 yr comment_458802 Also what's the dial that has open/close on it do?I take it you are "fair dinkum" asking these questions. The dial you are talking about is probably the "Shut/Open" vent under the steering column to direct air to the drivers leg area. It should be connected to a flexible tube about 1-1/2" in diameter, but that may have been removed by a previous owner to gain access to behind the dash.It might be a bit more social to explain who you are and what model S30 you have.Oh btw welcome to the club.Chas Link to comment https://www.classiczcars.com/forums/topic/50439-newbie-280z-question/#findComment-458802 Share on other sites More sharing options...
