Threehz Posted November 19, 2014 Share #1 Posted November 19, 2014 Attempting to reconnect this pipe from exhaust mani to intake mani and I cracked it thinking I could just turn it a little to re-align it. Can I easily (cheaply) replace this, can I weld it, what's the deal with this pipe? Link to comment Share on other sites More sharing options...
S30Driver Posted November 19, 2014 Share #2 Posted November 19, 2014 Looks like the pipe for the Exhaust Gas Re-circulation Valve.Tough to find a used one that is not already broken. I'm sure it could be welded. Many people delete it, as the parts parts can be expensive, a bolt in the threaded hole of the exhaust manifold & a block off plate where the EGR valve is. Link to comment Share on other sites More sharing options...
EuroDat Posted November 19, 2014 Share #3 Posted November 19, 2014 Yep. Its the EGR pipe. Mine broke in exactly the same place, just before I decided to delete it. I have some before and after photos of the fix. Ill post them tonight.Chas Link to comment Share on other sites More sharing options...
rcb280z Posted November 19, 2014 Share #4 Posted November 19, 2014 Keep checking ebay. I bought one (new) and no problems with it. I just looked and don't see any yet but I would check periodically.If it's not required for AZ I would do what is mentioned above. The only thing with that is if you move anywhere that has strict smog laws like CA you will run into problems. Link to comment Share on other sites More sharing options...
rossiz Posted November 19, 2014 Share #5 Posted November 19, 2014 mine was broken too - fell apart as i was taking off the (also broken) egr valve atop the manifold... Link to comment Share on other sites More sharing options...
Threehz Posted November 19, 2014 Author Share #6 Posted November 19, 2014 I thought it was related to the EGR, but had trouble finding any information on the actual pipe piece. Will deleting it cause any performance changes? Thanks for the quick help guys! Link to comment Share on other sites More sharing options...
rcb280z Posted November 19, 2014 Share #7 Posted November 19, 2014 No performance changes. It's there (EGR) to "clean" up the exhaust, in so many word. Link to comment Share on other sites More sharing options...
siteunseen Posted November 19, 2014 Share #8 Posted November 19, 2014 Seems like when I deleted mine there was a small hose going to the BPT valve? then from there to the side of the throttle body, driver's side. I had to plug that at the throttle body. Yellow circle in the attachment. Link to comment Share on other sites More sharing options...
EuroDat Posted November 19, 2014 Share #9 Posted November 19, 2014 Here are some photo's of my egr and the plug and plate fitted to the manifolds. I didn't need it here to pass emmisions regulations so it was easier for me to delete it. Chas. Link to comment Share on other sites More sharing options...
Patcon Posted November 20, 2014 Share #10 Posted November 20, 2014 I haven't ever seen one of these in person, but it seems like you could make one fairly easily with a flairing tool and reuse the nuts if necessary.C Link to comment Share on other sites More sharing options...
rossiz Posted November 20, 2014 Share #11 Posted November 20, 2014 i originally made a plate out of some 1/4" aluminum and just bolted it on & plugged the odd tubes going to it - then wound up completely restoring the manifold so while i was at it i cut off the extension and plugged it all up permanently. the exhaust gas recirculation system essentially allows unburnt fuel in the exhaust to pass from the exhaust manifold back into the intake for improved emissions. the egr valve is vacuum controlled, and when working correctly the recirculation occurs in a controlled manner that should not affect performance one way or the other. removal of the system, while allowing a little more unburnt fuel to pass out the tailpipe, doesn't add performance - it just cleans up the manifold area and eliminates a couple more potential vacuum and exhaust leak areas (my main reason for removal). Link to comment Share on other sites More sharing options...
beermanpete Posted November 20, 2014 Share #12 Posted November 20, 2014 As Patcon said, you can easily make a new pipe. The end that goes into the exhaust manifold has a compression bead to seal it. The other end, as shown in your photo, has a flare. Both easy to deal with. Replacing the pipe is likely easier than eleminating the EGR system, but elemination of the EGR is fine if you do not need to have periodic inspections. Link to comment Share on other sites More sharing options...
