Gas Tank Out - Interesting Problem
sdyck
Dropped my gas tank today. 1972 240z.. And I have an interesting issue.
The fuel retun pipe (small one on top in the picture) moves, it spins although if I pull it out a little it tightens up. I doubt it's intended to be a friction fit.
Has anyone had this issue? The tank is really clean id hate to have to have it cleaned out just to weld this up.
Any suggestions? Would you trust jb weld on this?
Thanks
post-29415-0-66992700-1416691785_thumb.j
Like nix240z said, just resolder it. Don't use any soldering iron that uses an open flame.
I've done it before not on a Zed, but it was similar. I washed out the tank first , as a precaution, and cleaned the area with a wire wheel and I used a mates plumbers soldering iron to solder the joint.
I had that car for eight years after that and it never caused any problems.
Chas
