For the record, I had the opportunity to test an EMPI synchrometer against an STE synchrometer and the readings on each were different.
I do not think they are calibrated well. The EMPI read higher at idle.
Sort of... that is the reality of what we are adjusting however, if you want to try to get an approximate bench mark at least ; one that many can use, it will be difficult. For example if a procedure states to set the RPM's to 850 at idle and one person's rpm tester was not the same as another's then it would be difficult to achieve the desired result. I would expect a better level of agreement between $50 test instruments with flow numbers on the case. I now have two flow testers my old EMPI and new STE that I will soon compare for bringing a third into the comparison.
