Posted November 27, 201410 yr comment_459377 I'm tired of crawling around positioning a floor jack when I need to get the car up in the air so it's time to look at a lift. My "shop" is a regular 3 car detached garage that doesn't have room for a two post. At this point I think it's going to come down to some brand of scissors lift and I'm interested in hearing what everyone else is using. Link to comment https://www.classiczcars.com/forums/topic/50503-z-garage-lift/ Share on other sites More sharing options...
November 27, 201410 yr comment_459394 Have you given a single post hoist any thought? It would give you better acess under the car and they can be ordered in a semi mobile unit.http://www.aaq.net.au/shop/detail/autolift-167251-single-post-lift/Chas Link to comment https://www.classiczcars.com/forums/topic/50503-z-garage-lift/#findComment-459394 Share on other sites More sharing options...
November 27, 201410 yr comment_459399 Theres also companies that make drive up ramps. Try raceramps.com Link to comment https://www.classiczcars.com/forums/topic/50503-z-garage-lift/#findComment-459399 Share on other sites More sharing options...
November 27, 201410 yr comment_459404 I have a set of the taller Race Ramps with the detachable ramps. They are very nice to use and don't slip easily with the Z even though I have a painted garage floor. However, if you need to lift your car to do the brakes, I think a scissor lift would be much better. Link to comment https://www.classiczcars.com/forums/topic/50503-z-garage-lift/#findComment-459404 Share on other sites More sharing options...
November 28, 201410 yr comment_459405 I've got the Danmar Max Jax and love it. Portable and and a really good solution if you don't have ceiling height. Requires some anchors and at least 4" of concrete thickness. Link to comment https://www.classiczcars.com/forums/topic/50503-z-garage-lift/#findComment-459405 Share on other sites More sharing options...
November 28, 201410 yr comment_459410 Yeah, I wouldn't turn that down. How difficult was it to get it delivered to your house? Link to comment https://www.classiczcars.com/forums/topic/50503-z-garage-lift/#findComment-459410 Share on other sites More sharing options...
November 28, 201410 yr comment_459412 On 11/28/2014 at 1:43 AM, SteveJ said: Yeah, I wouldn't turn that down. How difficult was it to get it delivered to your house?We have a local distributor here in Vancouver so delivery was no issue at all.I think Costco has them now. Link to comment https://www.classiczcars.com/forums/topic/50503-z-garage-lift/#findComment-459412 Share on other sites More sharing options...
November 28, 201410 yr comment_459415 Sure, mention that AFTER I tell my wife that we need to cut back on spending. Link to comment https://www.classiczcars.com/forums/topic/50503-z-garage-lift/#findComment-459415 Share on other sites More sharing options...
November 28, 201410 yr comment_459432 I've been looking at this for quite some time, just hesitant to pull the trigger... http://www.ezcarlift.com/ Link to comment https://www.classiczcars.com/forums/topic/50503-z-garage-lift/#findComment-459432 Share on other sites More sharing options...
November 28, 201410 yr comment_459444 I bought a Quick-jack BL-3500 from BendPak http://www.bendpak.com/Shop-Equipment/QuickJack/BL-3500.aspx I got the 12v versions so I could use it on the race car at the track. It works well, lifts the car 17" off the ground and it is much more stable than jack stands. If you will never use the portability of the lift, it comes in a 110v version as well. My only complaint is that it is kind of heavy, but that is because it it very well built. Marty Link to comment https://www.classiczcars.com/forums/topic/50503-z-garage-lift/#findComment-459444 Share on other sites More sharing options...
November 28, 201410 yr comment_459454 I'm in Australia but as far as I'm aware this is an international model that is rebranded so it should be available via a local-to-you company.It's like a Max Jax but when I did my research it suited me better.http://happ.com.au/hoist_and_lift/happ90-3t-two-post-hoist-fully-adjustable/ Link to comment https://www.classiczcars.com/forums/topic/50503-z-garage-lift/#findComment-459454 Share on other sites More sharing options...
November 29, 201410 yr Author comment_459480 I'm finding the Bend Pak BL3500 for $1035 shipped at Auto Body Tool Mart this morning, which is an attractive price. $500 Bucks more buys a cheap scissors lift but I'm finding this style clogs up the middle/underside of the car so I think I've talked myself out of going that route. The EZ lift looks like a nice piece but at almost twice the money of the Bend Pak it's not that nice. And I like that the Bend Pak has 3" ground clearance in the down position so my Datsun Roadster race car will roll over it. Hummm....looks like the BL3500 is leading the race at this point. Thanks for all the input. Link to comment https://www.classiczcars.com/forums/topic/50503-z-garage-lift/#findComment-459480 Share on other sites More sharing options...
