Posted November 29, 201410 yr comment_459466 Does anyone have a part number and source for the small light bulbs that are used in the console indicators for Choke, Fasten Seat Belt, and Rear Window Defrost switch. Mine just say 1.5 watts, 12 volts. Car is a '72. I've searched without any luck so far. Thanks. Link to comment https://www.classiczcars.com/forums/topic/50514-light-bulbs-in-console-indicators/ Share on other sites More sharing options...
November 29, 201410 yr comment_459469 Do you have the old bulbs in hand? If so, I could probably tell you the type. Could they be 194s? Link to comment https://www.classiczcars.com/forums/topic/50514-light-bulbs-in-console-indicators/#findComment-459469 Share on other sites More sharing options...
November 29, 201410 yr Author comment_459478 Here is a picture of two of the lights. The base is 0.268" in diameter. Link to comment https://www.classiczcars.com/forums/topic/50514-light-bulbs-in-console-indicators/#findComment-459478 Share on other sites More sharing options...
November 29, 201410 yr comment_459481 I found a part number on the microfiche but no images of it. It's number 23. http://www.carpartsmanual.com/datsuns30/DatsunZIndex/Body240Z/FloorConsole,FinisherAshTray/tabid/1769/Default.aspx Link to comment https://www.classiczcars.com/forums/topic/50514-light-bulbs-in-console-indicators/#findComment-459481 Share on other sites More sharing options...
November 29, 201410 yr comment_459489 Thanks for posting a picture. It's a BA7 bulb. Here's a source: https://www.superbrightleds.com/moreinfo/ba9s-ba7s/ba7s-led-bulb-1-led/10/#/attributes/16. Link to comment https://www.classiczcars.com/forums/topic/50514-light-bulbs-in-console-indicators/#findComment-459489 Share on other sites More sharing options...
November 29, 201410 yr Author comment_459501 Thanks. It is also available as a regular bulb Eiko 16037 - 3898. I ordered the LEDs. I'll update when I get them. Link to comment https://www.classiczcars.com/forums/topic/50514-light-bulbs-in-console-indicators/#findComment-459501 Share on other sites More sharing options...
