Here's the microfiche, http://www.carpartsmanual.com/datsuns30/DatsunZIndex/Engine240Z260Z/AirCleaner240Z(L24)/ToJun-72/tabid/1579/Default.aspx
If it's #11, I googled the part number and a few places had them.  Hope this helps.
A lot of times I can call my local Nissan parts department and give them the number and they can get the parts, sometimes the next day.  They don't like going back as far as our cars, they have to get out their microfiche, their computers don't go back that far.
  • 6 years later...
Late to the game! The air cleaner bolts from Nissan with the part number are now hex head. https://parts.nissanusa.com/p/Datsun__240Z/BOLT/89410733/16516-E3210.html
I just purchased a set of Datsun Roadster wing nut bolts that look to be the same thread and length. I will provide an update when they arrive.
Cheers, Kirk
  • 1 month later...
Cheers, Kirk
Okay - The Roadster bolts are a little longer then the 240Z bolts. I drilled out two aluminum hex head valve caps, which sealed the air cleaner against the seal.
Edited by 70 Fairlady Z
