Posted December 6, 201410 yr comment_459958 I need to figure out if the door windows are the same between 1974-76 model ad 77-78 model. I know the doors and mechanism are completely different. Link to comment https://www.classiczcars.com/forums/topic/50562-are-door-glass-for-1974-76-the-same-as-77-78-please-help/ Share on other sites More sharing options...
December 6, 201410 yr comment_459965 From the parts manual: 13 GLASS-DOOR WINDOW RH 80311-E4101 - 7506 1 80311-N4500 7507 - 7607 1 80312-N4400 7608 - 1 14 GLASS-DOOR WINDOW LH 80312-E4101 - 7506 1 80312-N4500 7507 - 7607 1 80313-N4400 7608 - 1 From that I would say that they are different parts. Link to comment https://www.classiczcars.com/forums/topic/50562-are-door-glass-for-1974-76-the-same-as-77-78-please-help/#findComment-459965 Share on other sites More sharing options...
December 7, 201410 yr Author comment_459987 From the parts manual:13 GLASS-DOOR WINDOW RH 80311-E4101 - 7506 1 80311-N4500 7507 - 7607 1 80312-N4400 7608 - 1 14 GLASS-DOOR WINDOW LH 80312-E4101 - 7506 1 80312-N4500 7507 - 7607 1 80313-N4400 7608 - 1 From that I would say that they are different parts.I know that there are Clear glass ones and blue glass ones. I am looking for brand new ones for 1977-1978 2+2. And I found ones for 1974-5. I know regulators are different between early type and later type. Link to comment https://www.classiczcars.com/forums/topic/50562-are-door-glass-for-1974-76-the-same-as-77-78-please-help/#findComment-459987 Share on other sites More sharing options...
December 7, 201410 yr comment_460011 You should have said 2+2 from the beginning. It looks like they changed after the 75 model year, as well. GLASS DOOR WINDOW RH80312-N3700 - 7506 180312-N4520 7507 - 1 GLASS DOOR WINDOW LH80313-N3700 - 7506 180313-N4520 7507 - 1 Link to comment https://www.classiczcars.com/forums/topic/50562-are-door-glass-for-1974-76-the-same-as-77-78-please-help/#findComment-460011 Share on other sites More sharing options...
December 8, 201410 yr Author comment_460040 You should have said 2+2 from the beginning. It looks like they changed after the 75 model year, as well. GLASS DOOR WINDOW RH 80312-N3700 - 7506 1 80312-N4520 7507 - 1 GLASS DOOR WINDOW LH 80313-N3700 - 7506 1 80313-N4520 7507 - 1 Thank you. But my question is are the glasses different shape at the bottom? Could early ones be fitted on later ones? I am looking for new ones for 77-78 2+2. Link to comment https://www.classiczcars.com/forums/topic/50562-are-door-glass-for-1974-76-the-same-as-77-78-please-help/#findComment-460040 Share on other sites More sharing options...
