December 18, 201410 yr comment_460539 1969 to 1983 z/zx 1/2 shaft u-joints are the same: http://www.thezstore.com/page/TZS/CTGY/classic22e04 Link to comment https://www.classiczcars.com/forums/topic/50588-mustache-bar-bushings-anything-special-i-need-to-know/?&page=3#findComment-460539 Share on other sites More sharing options...
December 20, 201410 yr Author comment_460601 Thanks again Blue! Think I'm gonna go look for some donor shafts that I can rebuild off the car. Link to comment https://www.classiczcars.com/forums/topic/50588-mustache-bar-bushings-anything-special-i-need-to-know/?&page=3#findComment-460601 Share on other sites More sharing options...
December 25, 201410 yr comment_460785 If you have a hard time finding some, send me a PM and I will look thru the shop. I probably have an extra set...Charles Link to comment https://www.classiczcars.com/forums/topic/50588-mustache-bar-bushings-anything-special-i-need-to-know/?&page=3#findComment-460785 Share on other sites More sharing options...
December 26, 201410 yr comment_460788 I still have the clunk after replacing about everything. One thing I noticed is that the mustache bushing stub mount bolt is tapered and it leaves a pretty good gap at the bottom. I attached a picture so you can see. I'm not sure how to remedy this if it were this the reason for the clunk. Link to comment https://www.classiczcars.com/forums/topic/50588-mustache-bar-bushings-anything-special-i-need-to-know/?&page=3#findComment-460788 Share on other sites More sharing options...
December 26, 201410 yr Author comment_460798 Found U joints, got a press from work, got ready to replace the u joints, and realized the fackin bolts on the drivers side half shaft vibrated loose. FAIL! -Tightened them up, thud was gone!-Next day, thud came back. -Driveshaft came loose. (Been having that issue, I ordered new bolts. PO just stuck random hardware in there.) -Still have a little thud with the driveshaft tight now. This car is a pain in my arse I'm just gonna throw a new joint on every shaft this spring since they don't seem loose now. Everything is tight, probably just had the driveshaft vibrate loose again. When the new bolts come in, we'll see what it does. Link to comment https://www.classiczcars.com/forums/topic/50588-mustache-bar-bushings-anything-special-i-need-to-know/?&page=3#findComment-460798 Share on other sites More sharing options...
December 26, 201410 yr comment_460804 Adjust the slave cylinder where the clutch slips a little. No more THUD. Just kidding. "fackin bolts", that's funny, reminds me of that old Michael Keaton movie "Johnny Dangerously". "You lousy cork-soakers. You have violated my farging rights. Dis somanumbatching country was founded so that the liberties of common patriotic citizens like me could not be taken away by a bunch of fargin iceholes... like yourselves." "You fargin sneaky bastage. I'm gonna take your dwork. I'm gonna nail it to the wall. I'm gonna crush your boils in a meat grinder. I'm gonna cut off your arms. I'm gonna shove 'em up your icehole. Dirty son-a-ma-batches!" Link to comment https://www.classiczcars.com/forums/topic/50588-mustache-bar-bushings-anything-special-i-need-to-know/?&page=3#findComment-460804 Share on other sites More sharing options...
December 26, 201410 yr comment_460806 The years hadn't softened Moroni. He continued to murder the English Language... And anyone who got in his way. Link to comment https://www.classiczcars.com/forums/topic/50588-mustache-bar-bushings-anything-special-i-need-to-know/?&page=3#findComment-460806 Share on other sites More sharing options...
December 27, 201410 yr comment_460823 That fargin bastage! Link to comment https://www.classiczcars.com/forums/topic/50588-mustache-bar-bushings-anything-special-i-need-to-know/?&page=3#findComment-460823 Share on other sites More sharing options...
