Posted October 27, 200123 yr comment_1077 z Link to comment https://www.classiczcars.com/forums/topic/506-are-warped-heads-common-on-a-240-nm/ Share on other sites More sharing options...
October 28, 200123 yr comment_1078 Yep, heads are pretty common on a Z. This is primarily due to the different metals used. For instance, the engine block is iron. The head is aluminum. Due to the different expansion/contractraction characteristics, your head can warp.Heads can also get warped because they weren't installed correctly. There is a certain pattern to tighten the head bolts. If this pattern isn't followed correctly, the head can be tweaked out of shape.A head can also only be milled so many times before it's no good. Link to comment https://www.classiczcars.com/forums/topic/506-are-warped-heads-common-on-a-240-nm/#findComment-1078 Share on other sites More sharing options...
