Posted December 27, 201410 yr comment_460846 Does anyone know of a quiet 4 psi fuel pump?I have the RX7 pump installed at the moment and although they claim that it's 4psi it is more like 2 which in my case lets the bowls empty by the end of the quarter mile strip.Thanks,Chris Link to comment https://www.classiczcars.com/forums/topic/50665-quiet-4psi-electric-fuel-pump/ Share on other sites More sharing options...
December 27, 201410 yr comment_460847 Chris,I have never had a lean issue with my pump and I run triples off the rx7 pump Link to comment https://www.classiczcars.com/forums/topic/50665-quiet-4psi-electric-fuel-pump/#findComment-460847 Share on other sites More sharing options...
February 28, 201510 yr comment_464565 I have an RX7 pump too and I just tried running it and got a very low, inconsistent flow of fuel. It doesnt even register on the gauge. Steve, did you use the supplied filter that came with it or just cut it off? Maybe thats my problem. EDIT: found my problem, needed more than 3 gallons in the tank. Edited February 28, 201510 yr by HaZmatt Link to comment https://www.classiczcars.com/forums/topic/50665-quiet-4psi-electric-fuel-pump/#findComment-464565 Share on other sites More sharing options...
February 28, 201510 yr comment_464569 It seems that the Mallory 4070 (4PSI) and 4110 (7 PSI) pumps are recommended for how quiet they are. Figured its recommended to run the Holley fuel pressure regulator with these units also. They are pricey though, and summit has a couple negative reviews regarding their dependability. I would like to find a quiet pump under 100 dollars also. Edited February 28, 201510 yr by nismospek Link to comment https://www.classiczcars.com/forums/topic/50665-quiet-4psi-electric-fuel-pump/#findComment-464569 Share on other sites More sharing options...
February 28, 201510 yr comment_464571 Anyone have experience with the Holley Mighty Mite 12-426?It is a 4 PSI unit with good reviews and it is supposedly quiet too. Link to comment https://www.classiczcars.com/forums/topic/50665-quiet-4psi-electric-fuel-pump/#findComment-464571 Share on other sites More sharing options...
March 1, 201510 yr Author comment_464573 This is what I ended up with, http://www.fuelpumpu.com/vehicle-search.aspx#2.5-4psi, mine measured out at a solid 3psi and that is better then what I had, hopefully I can finish the 1/4 mile this coming season.Chris Electric Fuel Pump E8016S Attributes Type Solenoid Volts 12 Inlet Type Strainer Outlet Size 5/16 in. Outlet Type Hose Bead GPH (Free Flow) 30 Max Pump PSI (Not System) 2.5-4.5 UPC 080044089940 Edited March 1, 201510 yr by grannyknot Link to comment https://www.classiczcars.com/forums/topic/50665-quiet-4psi-electric-fuel-pump/#findComment-464573 Share on other sites More sharing options...
March 1, 201510 yr comment_464575 This is what I ended up with, http://www.fuelpumpu.com/vehicle-search.aspx#2.5-4psi, mine measured out at a solid 3psi and that is better then what I had, hopefully I can finish the 1/4 mile this coming season.ChrisCouldn't get the link to work, was it some type of airtex model? How loud is it? Link to comment https://www.classiczcars.com/forums/topic/50665-quiet-4psi-electric-fuel-pump/#findComment-464575 Share on other sites More sharing options...
March 1, 201510 yr comment_464577 not to hijack, but what is the advantage of an electric fuel pump vs. the mechanical one? i've read that the stock mech. pump will happily feed a carbed L28, it makes no noise in the cabin and i like the simplicity of less wiring, fuses, relays, etc. reason i ask is i was planning on going this route on the F54/P79 that i'm building - any input would be greatly appreciated... Link to comment https://www.classiczcars.com/forums/topic/50665-quiet-4psi-electric-fuel-pump/#findComment-464577 Share on other sites More sharing options...
March 1, 201510 yr comment_464578 not to hijack, but what is the advantage of an electric fuel pump vs. the mechanical one? i've read that the stock mech. pump will happily feed a carbed L28, it makes no noise in the cabin and i like the simplicity of less wiring, fuses, relays, etc. reason i ask is i was planning on going this route on the F54/P79 that i'm building - any input would be greatly appreciated...My Z came with the mechanical fuel pump already blocked off. From what I hear, especially in hotter parts of the nation is that the car can be susceptible to vapor lock due to the fuel and lines being right by the engine. If you run the a electrical fuel pump, you can run a fuel line by the firewall to the carbs helping to reduce the amount of heat on the lines. Link to comment https://www.classiczcars.com/forums/topic/50665-quiet-4psi-electric-fuel-pump/#findComment-464578 Share on other sites More sharing options...
March 1, 201510 yr comment_464581 interesting - anything else other than the heat issue? Link to comment https://www.classiczcars.com/forums/topic/50665-quiet-4psi-electric-fuel-pump/#findComment-464581 Share on other sites More sharing options...
March 1, 201510 yr Author comment_464582 I changed to an electric pump for a few minor reasons, they are cheap, reliable, offer consistent flow,I wanted to change the route of the fuel line so it wasn't taking a tour of the engine bay. Now it comes out of the trans tunnel, straight up the firewall and dead heads into the carbs. I eliminated the return line altogether, also there is parasitic power loss from a mechanical pump, granted it's not much but all of theseitems together were enough reason for me.Chris Link to comment https://www.classiczcars.com/forums/topic/50665-quiet-4psi-electric-fuel-pump/#findComment-464582 Share on other sites More sharing options...
March 1, 201510 yr comment_464592 I like Chris's idea of re-routing the lines direct to the carbs when going elec, but I think heat is more of an issue with FI than SUs. 20+ years as a DD w/ stock set-up, my 71 didn't experience any temperature related problems in the fuel system. Many Summer days over 100`f. As far as parasitic power loss from a mechanical pump, you'll find a lot more loss in the engine cooling fan. But that is another topic.Mark Link to comment https://www.classiczcars.com/forums/topic/50665-quiet-4psi-electric-fuel-pump/#findComment-464592 Share on other sites More sharing options...
