I am about to upgrade my stock 240Z dizzy with a 280ZX pointless dizzy.
Naturally I want to match the coild and ignition system to give better peroformanc/better spark.
Any suggetions would be appreciated to more horsies :cheeky:
Biker
https://www.classiczcars.com/forums/topic/5067-ignition-upgrade/
from the block up. meaning the adapter to the block and all.
get at least a 45000 volt coil, remove your ballast resistor, you will no longer need it. you will have to switch to a 280 Z tach though i dont know about what you have down under.
either that or a tach adapter from msd might work not sure on that one.
besides that its really easy and will only take a few minutes to complete.
good luck
